Results 1 to 5 of 5
    Default new to Inspire & Andriod need upgrade help pls
    Hey there, I would like to upgrade from 2.3.3. to 4.0 please
    can someone please help me out thanks
    There's one app I would like to install and for some reason it's saying incompatible so I'm guessing it's cause the ROM isn't updated.
    Am I right?
    thanks
    G
  2. #2
    Dave Begue's Avatar
    Posts
    Carrier
    stock
    Default Re: new to Inspire & Andriod need upgrade help pls
    I think the only way to upgrade is by root and custom rom install. I am thinking about trying it myself after a while. From what I've read that ace hack kit is the best way to do it. I bought an unbuto cd so I can do it more easily without the windows/driver pit falls
  3. #3
    Ronnie2's Avatar
    Posts
    Carrier
    paranoidKangdroid
    Ya use the hack kit, its by far the easiest way to root and S-off the Inspire. Its not all that bad rooting with Windows just download HTC Sync and it installs all needed drivers. Link is below.
    [TOOL] Advanced ACE Hack Kit (12062012) w/ENG Support - xda-developers
    I've heard good things about this ICS rom, try it out if you're feeling up to it.
    [ROM][JUNE 03][ICS 4.0.4] aospX 1.0.0-BR2 | IMM76I | Source | WIP - xda-developers
    Thanks for the help guys I will try and. And when I do will be able to put on the latest Droid OS right?
    Dave let me know how it works. Thanks
  5. #5
    Ronnie2's Avatar
    Posts
    Carrier
    paranoidKangdroid
    Default
    Quote Originally Posted by Gawain Fraites View Post
    Ya after rooting you'all be able to flash an Ice Cream Sandwich rom. You should have no problem rooting with the Advanced Hack Kit, provided you follow the instructions
    Sent from my A500 using Tapatalk 2
