1. ken james's Avatar
    my htc inspire 4 g has some serious issues.. when ever i try to open an app it shows the " force close" error.. every single app i try to open it shows that error.. i tryed to factory to factory reset but it wont.. i try all the methods of factory resetting but it wont work.. the phone just wont factory reset..in boot loader it shows this
    unlocked
    ace pvt ship s-on rl
    hboot-2.00.0030
    microp-0438
    radio-26.17.11_m
    emmc-boot
    feb 20 2012,16:30:18
    it is currently running
    android version 2.3.5
    htc sense 3.0
    software number 3.20.502.52
    kernel 2.6.35.10
    can anyone help.. not sure if am supposed to try root it again or anything.. i have try to put custom roms but the dont work.. they show installation complete and the phone boots back up with no change.. running the same stock rom i had before i try to flash it. seems like the customs roms dont work or maybe the device if not fully rooted??? please helpp
    04-26-2014 06:42 PM
  2. wizzrah's Avatar
    unlocked
    hboot-2.00.0030
    microp-0438
    radio-26.17.11_m
    emmc-boot
    htc sense 3.0
    kernel 2.6.35.10
    What recovery are you running?
    04-26-2014 06:51 PM
  3. ken james's Avatar
    clockworkmod recovery v5.8.1.5
    04-26-2014 06:55 PM
  4. wizzrah's Avatar
    You are suppose to backup and wipe before flashing a new ROM.
    04-26-2014 06:59 PM
  5. ken james's Avatar
    can u give me more details as to how to do this???
    04-26-2014 07:03 PM
  6. wizzrah's Avatar
    I can't give you specifics because I don't have an HTC Inspire, but in CWM you hit backup/restore and then wipe/factory reset.
    04-26-2014 07:08 PM
  7. ken james's Avatar
    i just did that and install from zip and the sme thing.. nothing hasd chnaged.. the same rom on it with the same errors
    04-26-2014 07:25 PM
  8. wizzrah's Avatar
    So you wiped, and then re-flashed the ROM and nothing has changed? That could be a problem with the zip itself. Try a different ROM.
    04-26-2014 07:32 PM
  9. ken james's Avatar
    i got 3 roms and they all do the same thing
    04-26-2014 07:34 PM
  10. wizzrah's Avatar
    Since your HTC Device is S-ON, you might have to flash the boot.img.
    04-26-2014 07:35 PM
  11. ken james's Avatar
    how to u do that??? and does the s on mean my phone is not rooted??
    04-26-2014 07:42 PM
  12. wizzrah's Avatar
    If you want to check if you have root, you should try root checker from the play store. I don't know if it will open in your case though.
    Check this out: [Tutorial] How to flash a new boot.img via Fastboot - xda-developers
    If you don't know where your boot.img is, look inside the folder of the zip you flashed. You have to do this from your PC. Make sure the zip on your PC matches the one you flashed in recovery.
    04-26-2014 07:48 PM
  13. ken james's Avatar
    i keep gettiong this md5 mismatch
    04-26-2014 08:46 PM
  1. UXToolkit HTC One M8 AT&T [Unlock bootloader, flash recovery, root, S-OFF]
    By wizzrah in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 11-22-2014, 03:27 PM
  2. Help - Erasing SD Card before sending back to SanDisk
    By thewatrb0y in forum General Help and How To
    Last Post: 04-27-2014, 10:33 PM
  3. Minor Issues
    By heyheyhey97 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-26-2014, 06:56 PM
  4. Some help for the S5
    By cardboard60 in forum Samsung Galaxy S5
    Last Post: 04-26-2014, 06:17 PM
  5. Msn emial issues with the galaxy 5s
    By djjeffa in forum Samsung Galaxy S5
    Last Post: 04-26-2014, 05:21 PM
