Results 1 to 2 of 2
    Default A few issues after rooting.
    So I have had my HTC inspire for a little over a week or so. I have had it rooted for about that same time. The phone has been great. Faster speeds. Faster CPU. Love everything. The 2 issues I have are horrible sound quality when talking on the phone, horrible speaker quality, and last is every once in a while I receive a text message and the notification doesnt dissapear from the notification bar that the top until I manually clear it. Are there any fixes for these issues?
  2. #2
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    Default
    What method did you use to root the phone?.... if you used the Hack Kit...which is also used for the Desire, it downgrades to the stock Desire HD ROM to be able to S-OFF the device, which messes with the sound. This is due to different sound hardware used in the phone. It can be fixed by installing a custom ROM or kernel intended for the Inspire 4G with the sound issue fixed. If this is what you did I will post the guide to fix the sound for you. Let me know if this is the method you used.
