Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By jayboy005
    Default please help im stuck at bootloader screen!!!
    I can use my inspire anymore. it is stuck at the bootloader screen. i tried to load a rom with rom manager and it is stuck. now it wont reset to factory, restore, recover reboot anything. .... please help!!!!!!!!!! i have to go to work and my phone is fried...
  2. #2
    genuino's Avatar
    Posts
    Global Posts
    129 Global Posts
    Default
    Pull battery out while on bootloader screen, wait 5 minutes, put it back in, if it goes back to the boot screen you can browse through the options to just reboot the device. Hoe it helps.
    Default
    it only reboots to the bootloader...??? pls help
  4. #4
    genuino's Avatar
    Posts
    Global Posts
    129 Global Posts
    Default
    On the HBOOT screen, you should have a second list with fastboot, reboot and a few other things, if you don't, press power button once to show another set of options, using the volume button + or -, you can choose to reboot by pressing the power button again on the top of the phone.
    Default
    i have all of the options as i said... it just wont do them... every option goes back to white bootloader screen and thats it.
    bajan Bajan likes this.
  6. #6
    Default oops
    Might need to check the forums on how to unroot and follow those instructions to flash it back to stock.... just a thought...
    Default
    i cant unroot or anything. all i can do is look at the fastboot menu and bootlaoder. i can scroll through menus and pick options such as factory reset, recover, etc... but all just return to fastboot/bootloader menu. So there is no way to do anything, let alone unroot and flash back to stock. all my backups are on the sd card but i cant access it because im stuck at the fastboot/bootloader screen... there seems to beno image on my interneal memory...??? any help would be appreciated. I cant do anything right now. my old n900 used to be able to be flashed from the pc using a usb cord, do i have that option with android??
  8. Thread Author  Thread Author    #8
    Default
    anybody??
    Default
    really? no one has any options for me or suggestions? anything? i am seriously stuck with a bricked phone. Some help would reeeaallly be appreciated...
  10. #10
    Default
    Go over to XDA developers and look there for a stock version of the PD98IMG.zip file. (This is the stock ROM that your phone will always update from if it sees it on the SD card) Try putting it on your SD card and the bootloader should find it and try to update from it. Depending on what method you used to Root you may have the file still on you computer.
    XDA has a lot of people that have messed their Inspires all up and almost everyone has got them back. I screwed mine up and it took 7 hrs, lots of stress and lots of reading but I got it back. The trick is finding a copy of the Stock ROM to push onto your phone.
    Good Luck!
  11. Thread Author  Thread Author    #11
    Default
    Quote Originally Posted by bmolloy View Post
    Good Luck!
    Thank you very much for your response. Please let me ask you, I made a backup of the stock rom and it is currently on the sd card, wouldn't that be all I need? And also, are you saying that if I go and find that pd98img.zip and place it on my card that the bootloader should pick it up automatically?
  12. #12
    Default
    I am not sure what you did to end up where you are but when you have a file named PD98IMG.zip on your SD Card your phone tries to update from it. If it is an updateable file it will do it. It might be worth it for you to try the simple root again because it will push those files back onto your phone where you need them. You will have to go through the whole process again, but you already have a gold card if you did the simple root so that makes it a little easier. Go over to . They have the great community of people dealing with the Inspire over there. It is hard to brick the phone, you just need to have the right Operating system on there.
  13. #13
    homescrub's Avatar
    Posts
    Global Posts
    385 Global Posts
    ROM
    GingerBeast & CM7
    Default
    follow these instructions:
  14. #14
    Default Re: please help im stuck at bootloader screen!!!
    Quote Originally Posted by jayboy005 View Post
    Did you ever fix yours I have the same issue?
  15. #15
    Ronnie2's Avatar
    Posts
    ROM
    paranoidKangdroid
    Quote Originally Posted by roshmcn5455 View Post
    Use the Ace hack kit to flash the stock rom and re-root it. Should have your phone working again in no time. If it asks, you want to keep your phone S-off.
  16. #16
    For anyone on google who still has this phone, i fixed my problem by flashing a rom from xda developers that was the rooted stock updated inspire rom (with sense 3.0) and it booted again
