I need to return my Inspire 4g and I have to unroot. Since ive rooted it I dont get calls or texts and My roommate get them on her iphone 4 man I hate iphone. Can anybody help?
hey i just rooted my phone and dont really like it, so i tried returning it to stock and everything seems fine but i dont have sound anymore is there anyway to fix this?
I used ace hack kit v11a. i went through all the steps and got it rooted with s-off and everything. and i wasnt to crazy about it so then i click on the return to stock menu option and it removed super user and rom manger which was great. but then i just noticed that i dont have sound
Is their a video that can show you how to do this or a step by step guide.
I am trying the RUU method.... but my phone always gets stuck at the HTC screen.... There's no progress bar on the phone.... On the PC, it says "Sending............ "
I must have tried this about 6-7 times by now. The phone always gets stuck on the black screen with the silver letters 'HTC'..... I had used the goldcard method and loaded coredroid gingerbread rom....
Somepne please help.... I need to return the phone back to the store
Homescrub I downloaded that RUU and everything is working fine, but is that all I need to do? Don't I have to turn S-on or is that okay if I don't.To downgrade your phone back to stock, you can download the current radio: RUU_Ace_Cingular_US_1.80.502.3_Radio_12.39.60.19_2 6.06.04.06_M_release
Download RUU
RUU_Ace_Cingular_US_1.80.502.3_Radio_12.39.60.19_26.06.04.06_M_release_166557_signed.exe - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
Once you've downloaded it, run the program, then connect your inspire via USB, and run it. The RUU will de-root the phone and bring it back to Sense UI.
You will loose all data and apps, but im sure you've had it backed up through your Google ID. This also works for phones that are stuck on repeating reboot, and need to re-root the phone.
Note: Be sure to have HTC Sync uninstalled on your PC before running RUU. Only keep your HTC Inspire Drivers.
