Results 1 to 19 of 19
    repsolnow@gmail.com's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Anyone else heard or experienced the ghosting issue on this phone?
  2. #2
    justinlara313's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: LG G2 Flex: Ghosting
    Yes, big time. Especially when brightness is low
  3. #3
    wase4711's Avatar
    Posts
    Global Posts
    421 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    brightness set to auto, and I have NEVER seen it..
    Jupiter600 likes this.
  4. #4
    enik's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gingerbread Deck, Matrix
    I see graininess on anything grey
    Sent from my LG-LS980 using Tapatalk
  5. #5
    wase4711's Avatar
    Posts
    Global Posts
    421 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    others have said brightness at 70% or more fixes they grey issue for them
  6. #6
    enik's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by wase4711 View Post
    yea but I don't want to have to crank up the brightness. Well not that I don't want to but I shouldn't have to. It reminds me of my galaxy nexus display!
    Sent from my Lumia 928
  7. #7
    wase4711's Avatar
    Posts
    Global Posts
    421 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    why would you care about doing something that fixes something that bothers you?
    makes no sense...
    this battery lasts forever, so thats not even an issue
  8. #8
    enik's Avatar
    Posts
    Global Posts
    1,004 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    makes no sense...
    Because I watch a lot of videos at night when I like to have the screen brightness low? Does it matter? You shouldn't have to crank up the screen brightness to get rid of the issue on a $200+ device. Its not the end of the world, but really its an issue that could have been fixed preproduction
    Lestah_613 likes this.
  9. #9
    Lestah_613's Avatar
    Posts
    Global Posts
    218 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I paid 300 on ATnT for this phone so I too am peeved about this issues. But the battery life alone is enough to stick with it.
  10. #10
    alhadee12's Avatar
    Posts
    Global Posts
    123 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have not experienced the ghosting issue. My screen its pretty good and I have a Note 3 also.
    Sent from my LG-D950 using Tapatalk
  11. #11
    ffejjj's Avatar
    Posts
    Global Posts
    2,668 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lestah_613 View Post
    Not sure what LG is doing but it seems they're surely on the right path as far as battery goes
  12. #12
    alhadee12's Avatar
    Posts
    Global Posts
    123 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you looked at swapping it for another Flex?
  13. #13
    txgrunt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have experienced the screen rentention with this device. Apperently its normal? I have my brightness set to 50%. I may have to try the 70% brightness as stated in an earlier post.
  14. #14
    BassSoLow's Avatar
    Posts
    Global Posts
    166 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just got the flex yesterday. The phone is great, but the retension issue is awful. I used it last night to watch netflix...in a dark room it was definately noticalbe. The retension lasts anywhere from 3 to 10 seconds on my device.
    However, using it during the day (from my short experience this morning) has been better. Its not as noticable in higher light areas. And, as stated prevoiusly, pushing your brightness up helps a ton...the battery drops a bit quicker, but the battery in the device is a beast.
    Definately annoying though along with the grainy look of gray and whitish screens.
    Not really sure im going to keep the device yet.
    There are pluses and negative sides to all devices. I just have to see if I can live with looking a severly inferior screen to the competition.
  15. #15
    Relgoshan's Avatar
    Posts
    Global Posts
    1,062 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it makes a lot of sense the wallpaper was a starfield to reduce noticing this in the store. Better than the default wallpaper being a bruised purple sunset...
  16. #16
    04redgto's Avatar
    Posts
    Global Posts
    941 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its normal, you have to remember ur dealing with the first generation POLED device. Just the chance you take. I max out the brightness on all devices i get, so dosent bother me at all...
  17. #17
    SCD23x's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just bought mine yesterday and yes, it is noticeable. I keep my screen at 100% brightness and still notice it, although not as much as when the screen is set on a lower brightness setting.
    HOWEVER, I will say that the strengths of this phone strongly outweigh the ghosting issue, IMO. I'm coming from a Nexus 5, which I loved, but I missed the large screen size of the Note II that came before it. The phone has bloat, no doubt, but it pales in comparison to the bloat my Note II had.
  18. #18
    bwhick7492's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have used mine for about 5 days now at 50% brightens and have not seen the ghosting. I love this phone mainly because of the battery. I can easily get through two days with moderate to heavy use.
  19. #19
    Quincy Ferree's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We're talking about the flex 2 I've had no ghosting or grey problems at all and the brightness is always turned down all the way unless I'm walking outside overall I think it's a great phone but I need help fixing the ghost data problem my storage being used by the system according to the storage app in settings is at 9 GBs
  1. Samsung Galaxy S3 Ghost data problem
    By scynz1 in forum Samsung Galaxy S3
    Last Post: 11-17-2015, 06:36 AM
  2. Ghost Armor anyone?
    By Gunnyman in forum Moto X (2013)
    Last Post: 01-27-2014, 10:45 AM
  3. Ghost 100 Charger
    By jennharley11 in forum Motorola Droid 4
    Last Post: 01-09-2014, 04:28 PM
  4. MIME Ghost
    By Simon_y7 in forum Samsung Galaxy Note 3
    Last Post: 12-26-2013, 08:22 PM
  5. Replies: 6
    Last Post: 12-19-2013, 02:29 PM
