Results 1 to 2 of 2
    usamg's Avatar
    Posts
    Global Posts
    7 Global Posts
    Default LG G Flex: Video and Voice Recording Problems
    My LG G Flex is from AT&T. I did not try recording videos or voices right away, but after all the apps and settings completed, I've found that I can't record video. The top panel with the 4 functions disappear when I click on the red button. There's also no voice recording in any messenger-typed apps, voice memo, or voice command. Please help if there's anything I've disabled or I need a factory reset. Thanks.
  2. #2
    Default Re: LG G Flex: Video and Voice Recording Problems
    When you start recording the 4 functions are meant to go away. You can't change your recording options in the middle of recording. You should see in the top left, the light toggle button and "audio zoom". And in the middle the mode you chose, mine says "normal mode". And in the top right. You're record time "00:00:00" and "REC"
    And I just went to the play store and typed in voice recorder. And downloaded one of those. Works like it's stock. I use "Smart Voice Recorder", Long press your saved recordings and it gives you options to share in messages, email, etc.
    Sent from LG-D950 / LG G Flex using AC Mobile App
  1. 5 day old S5 and the "Ok Google" feature has stopped working
    By JClintB in forum Samsung Galaxy S5
    Last Post: 07-30-2014, 03:22 AM
  2. Choosing between the s4 zoom and lumia 1020
    By reelon in forum Samsung Galaxy S4 Zoom
    Last Post: 05-12-2014, 01:24 AM
  3. Weekly Photo Contest: Focus and Blur
    By Andrew Martonik in forum Photo Contests
    Last Post: 04-22-2014, 11:45 PM
  4. Replies: 0
    Last Post: 04-16-2014, 08:11 PM
  5. Kindle Fire HD root problems
    By ncvtec1313 in forum Amazon Kindle Fire HD
    Last Post: 04-16-2014, 07:44 PM
