G pad 7.0 factory reset does not work
Austin Piacitelli
I rooted my g pad and it was working fine. As soon as it turned off it would stay stuck on lg logo. I've done hard and soft resets and it still gets stuck on the logo
At first it was stuck on lg logo and then I tried hard reset, soft reset and safe mode and it would always just stay on the logo but after random combinations I kept doing now resulted in blank screen and every 4or5 second the at&t logo flashes quickly
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,280
4,389
113
Welcome to Android Central! I merged your similar threads.
Did you modify your tablet in any way after rooting? Like installing a custom ROM, or deleting system apps?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,280
4,389
113
I don't have any direct rooting experience, so I can't say for sure -- but I'd suspect that something you deleted might have been more important than it appeared. Can you list what you deleted? Also, did you make a backup before deleting?
