06-22-2016 01:54 PM
50 12
tools
  1. Nychotxxx's Avatar
    I thought I'd start a thread just on battery life to see how other users are doing. Mine is terrible. I get maybe 5 or 6 hours tops before its down to 20% or less and needs refueling. Its like a hummer, lol. After a week battery life is my only issue. Otherwise its a great tab. Either some of these units have bad batteries or those claiming great battery life are exagerating. If the former, lg has to step up. Thoughts?
    11-11-2013 01:35 PM
  2. mrstarzan's Avatar
    What do you mean by 5-6 hours? What is your screen on time? What brightness level?
    Sent from my VS980 4G using AC Forums mobile app
    11-11-2013 02:11 PM
  3. joshuadjohnson22's Avatar
    also check for apps that wake your tab up from sleep while idle
    11-11-2013 02:51 PM
  4. erwaso's Avatar
    At 80% brightness, I just played dead trigger 2 for 2 hours straight and I'm at 75% battery. That's as good as my I pad 3.
    11-11-2013 02:59 PM
  5. Nychotxxx's Avatar
    That's what i mean. You get long !life, I get little. I can drop 10 or 15 percent in an hour just surfing, reading articles, email with screen at 50-60 percent, WiFi on. Nothing else of consequence turned on like blue tooth etc. Its frustrating.
    11-11-2013 04:14 PM
  6. AmicusBrief's Avatar
    Mine's doing the same thing. With wifi on, web browsing, 50% brightness, I'm getting 4 minutes per 1% battery life. Seems kinda poor to me.
    11-11-2013 04:21 PM
  7. Nychotxxx's Avatar
    Agreed!!! Seems complaints to LG are in order. Its embatrasing how quickly the battery runs down.
    11-11-2013 04:24 PM
  8. Nychotxxx's Avatar
    Such as????
    11-11-2013 04:26 PM
  9. Drak_h's Avatar
    Try a factory reset. Have worked for others.
    11-11-2013 04:27 PM
  10. erwaso's Avatar
    It can happen to any device. The first day i complained that my battery drained over night. Now i dont see that happening. Ended at 39% and woke up to 39%.
    Battery mileage may vary lol. Like another stated, factory reset OR exchange it. Dont keep a faulty unit.
    11-11-2013 04:55 PM
  11. AmicusBrief's Avatar
    Just did a full factory reset. Didn't install any apps, changed brightness to 50%, auto off. Now I've dropped to 3 minutes for every 1% of battery. 45% battery indicates I have 1 hour 32 minutes of use left.
    11-11-2013 04:59 PM
  12. RussellmaniaKW's Avatar
    might want to check your math. 3 minutes per 1% means that at 45% charge remaining you'd have 135 minutes remaining or 2.25 hours. Still not great, but it's more accurate than your calculation.
    11-11-2013 05:04 PM
  13. Nychotxxx's Avatar
    Wow! That is horrific. Factory reset is what tech support people tell you to do when they dont know the solution and want to get you off the line.
    11-11-2013 05:07 PM
  14. AmicusBrief's Avatar
    First off, I used a stop watch to time a decrease in battery power by 1%. The 1 hour 32 minutes remaining was displayed under battery usage in the settings menu. I didn't calculate ****. If the math is F'd up its in the device.
    11-11-2013 05:11 PM
  15. RAHIEM69D's Avatar
    That's actually pretty good battery life at 80%. I can easily get through a day of gaming, surfing etc at 57% brightness. I'll try my brightness at 80% and report back.
    steveb_12 likes this.
    11-11-2013 05:40 PM
  16. RAHIEM69D's Avatar
    Wow, calm down man, I don't think that he was trying to insult you. Anyway, varying battery life is like that with all tablets/phones. My Ipad 3 had TERRIBLE battery life, yet my friends would last all day. My LG g pads battery life seems to have gotten much better with constant usage. Also, certain apps can kill your battery. Download an app called Wakelock Detector to see what's killing your battery life.
    11-11-2013 05:45 PM
  17. AmicusBrief's Avatar
    I'm calm, and I'm also not so stupid I can't do simple math. Nor, do I need some hack telling me of "their" assumed error.
    On a better note, I came up with a quick fix for the battery issue....I took the tablet back to Best Buy for a refund. Problem solved.
    11-11-2013 06:08 PM
  18. Nychotxxx's Avatar
    I'll bet a ton will be returned for the battery issue if its widespread. I'm hanging in with mine. I really like it and maybe the battery issue will improve.
    11-11-2013 06:21 PM
  19. RussellmaniaKW's Avatar
    you're the one that kept stating how many minutes you were getting per each percentage of battery life, so why wouldn't I assume that you calculated the time remaining? And if you were using battery at a certain observable rate then why do you care what the OS is saying when you are observing a totally different rate of discharge? You stated your own calculated rate of battery usage, but then also quoted the OS's estimate...sounds to me like you need to make up your mind which one you want to believe since they are obviously different.
    11-11-2013 06:37 PM
  20. MarkFL88's Avatar
    I have not done any actual times but my battery life seems decent definitely better then my Samsung Galaxy Tab 3 which my wife now uses. I will do some actual times this week and report back. If your tablet has a problem you should exchange it for another one. I brought my first G Pad back for the blue line issue and light bleed I am glad I did my 2nd one is perfect. Am I happy I had to take my first one back? No, but I would not let one bad device discourage me from trying again with this tablet.
    11-11-2013 06:48 PM
  21. erwaso's Avatar
    It's too bad some folks take the one experience and generalize all the models the same without a 2nd chance.
    No mass produced electronics device goes without a bad apple or ten.
    Good luck either way.!
    11-11-2013 07:55 PM
  22. L1VESTRONG's Avatar
    In my case battery life is not that great as well. When i full charge the tablet, i see that after 2 hours without using the tablet, battery life drops around 13-15%. It seems that when battery percentage goes to 80% and under then it doesnt drain that fast. Overall i have 5-6 soc with brightness level at 35%. Maybe some batteries are defective i think.
    Sent from my LG-V500 using Tapatalk
    11-12-2013 08:53 AM
  23. erwaso's Avatar
    sorry to hear. that's really bad
    Just watched a 2hr 10min movie and played Dead Trigger for an hour after with screen at 50%, then browsed the net for an hour. had 44% left.
    Battery Use in settings shows
    11-12-2013 04:47 PM
  24. MarkFL88's Avatar
    That is not normal you need to see if you have an app running or preventing the tablet from really sleeping. My tablet when charged to 100% I put it to sleep and went to bed when I checked 7 hours later I was at 98% I find this about normal for all my Android tablets I would loose about 3% overnight. If it is not an app I would exchange it if you still can,
    11-12-2013 05:36 PM
  25. Drak_h's Avatar
    New picture of my battery life. My battery is so great
    And on idle, battery doesn't go down. Maybe 1% on 8-10 hours.
    11-12-2013 06:12 PM
50 12
  1. Replies: 54
    Last Post: 03-07-2014, 12:40 PM
  2. Handcent not sending MMS
    By Cyrene in forum Verizon Samsung Galaxy S4
    Last Post: 11-13-2013, 03:43 PM
  3. Capacitive Buttons Not as Responsive After Update
    By bhameyedoc in forum Motorola Droid MAXX
    Last Post: 11-12-2013, 09:39 AM
  4. Question about resetting battery stats?
    By Hugh Johnson in forum General Help and How To
    Last Post: 11-11-2013, 03:11 PM
