03-02-2014 08:12 PM
  1. techie5's Avatar
    Does anyone know if the power cord I have for my Lgg2 would also work on the lg g pad?
    Thanks
    03-01-2014 10:08 AM
  2. Paul627g's Avatar
    I can't say for certain but 99.9% of the time any mini USB cord/charger will work between smartphones/devices. I've used HTC cords/chargers on Samsung and vise versa, same goes for using Blackberry or old Palm chargers on my newer Android stuff.
    Only thing it might affect is charge times, if the charger/cord is rated at a lower amperage than the stock/OEM cord it may charge at a slower rate.
    But never the less this is a good question and was worth asking
    Paul
    Moderator Team Leader @ Android Central.
    03-01-2014 10:33 AM
  3. ffejjj's Avatar
    Thanks
    I interchange my G2 and Gpad cords all the time with no ill affect.
    Paul627g likes this.
    03-01-2014 10:49 AM
  4. stevenkisor1's Avatar
    Thanks
    When I got my G-Pad I used the supplied AC adapter, but used the USB cord from my Note 2 because its longer, almost 6 ft. I was rather unhappy with the charge time, but accepted it.
    One day I was changing cables around, and finally used the USB cable that was supplied with the G-Pad. And I made this cable change during a charge cycle of the unit. The battery charge graph (under battery options) changed dramatically! I know this sounds unreal, and unless I saw that graph line change from a 15 degree incline to a 45 degree incline, I would not have believed it myself. The only explanation I could think of, would be the guage of the wire in the Samsung Note 2 vs LG's.
    I made this comment in a different thread last month or so, and another person responded that they also had the same results.
    techie5 likes this.
    03-02-2014 08:12 PM
  1. Cutting the Cord?
    By tacdroid in forum Google Nexus 4
    Last Post: 03-11-2014, 09:05 PM
  2. micro usb cord
    By Luke Underhill in forum Nexus 4 Accessories
    Last Post: 03-01-2014, 06:09 PM
  3. power off or not?
    By techie5 in forum LG G2
    Last Post: 02-28-2014, 09:03 PM
  4. Nexus 7: power off or leave it on? which is better?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-25-2014, 03:48 PM
  5. Ultra Power Saving Mode
    By Ry in forum Samsung Galaxy S5
    Last Post: 02-24-2014, 02:48 PM
