Audio BADLY out of sync when using bluetooth
bearpaw83
4
Audio is terribly out of sync when using Bluetooth on this device. I have a Bose Sound Link Mini and it works fine on everything else. Netflix, Google Play, anything with audio including keyboard clicks is way out of sync when using Bluetooth on my LG G Pad. I bought this mainly for videos so I am extremely disappointed.
Anyone have a fix for this?
Welcome to Android Central! What wi-fi frequency are you using at home? If you're on 2.4 GHz, try changing to 5 GHz (if available), since 2.4 GHz might interfere with Bluetooth. If you don't have 5 GHz on your router, then try changing your wi-fi channel. See this article for more info (although it's pretty old--not sure if things have changed since then): https://forums.androidcentral.com/e...WiFi_Bluetooth_coexistance.pdf&token=vOaUiETL
McAllister81
