• 4
    Unable to install system update
  • 1
    Nougat 7.0 arrives on LG g pad X 8
  • 1
    Reistall OS
  • 2
    How does it compare to the Gpad F 8.0?
  • 1
    Just Ordered Two
  • 2
    Connecting to a Projector
  • 2
    Broken screen touch screen
  • 4
    External MicroSD card for apps?
  • 2
    Turn Off 4G?
  • 3
    Thin case for LG G Pad X 8.0
  • Thread Display Options
    Use this control to limit the display of threads to those newer than the specified time frame.
    Allows you to choose the data by which the thread list will be sorted.
    Order threads in...
    Note: when sorting by date, 'descending order' will show the newest results first.
