Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By JTastic42
  • 1 Post By Donald Orlopp
    The_PLBs's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon LG G2 won't stay connected to 4G
    My new G2 will boot up and immediately go to 4G LTE but then goes to 3G and never will return to 4G. Anyone else have this issue?
  2. #2
    JTastic42's Avatar
    Posts
    Global Posts
    24 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Verizon LG G2 won't stay connected to 4G
    I'm also having that issue. After talking to a Verizon rep on the phone, it's probably either the sim or the phone. I'll post again when I have a chance to go into the store.
  3. #3
    rsjet's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not having this issue at all. Mine connects and stays connected to 4G where my Galaxy Nexus used to stay on 3G.
    The_PLBs's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by JTastic42 View Post
    I appreciate that.
  5. #5
    stew930's Avatar
    Posts
    Global Posts
    56 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I haven't noticed that issue but I am on WiFi most of the time. I will shut WiFi off and see how 4G is on mine.
  6. #6
    JTastic42's Avatar
    Posts
    Global Posts
    24 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by The_PLBs View Post
    I appreciate that.
    Well after making the trip, it was definitely a faulty SIM. After a quick swap, 4G has been rock solid.
    Goingcarcrazy likes this.
    The_PLBs's Avatar
    Posts
    Global Posts
    93 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine was the SIM card as well. Been fantastic ever since I swapped it Friday. The Verizon guy told me to always ask for a new SIM if they are preloaded in the device whenever you buy a new phone.
  8. #8
    Donald Orlopp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have had the same issue as you all did. I have an old sims card that was in my old droid 4 phone. My coverage kept losing 4g and no matter what I did no 4g in sight. I have a sims card that came with the lg g2 and after a long time of suffering with this problem I called tech support. He tracked down the problem to the sims card I had in the phone. Long story short the problem lies in the old sims card. The old card was primary a 3g card so the device would try to go to 4g and it did on a temp basis but after a 2 to 3 minute period it would never go back to 4g without the reboot. I had tech support check it out and after we activated the proper sims card...poof... all better! The problem lies in the sims card. Call tech support and it will fix your problem. Hope this helps everyone by offering a solution and exposing the problem so everyone understands the issue..
    BecomingDeath13 likes this.
  9. #9
    buckchuck27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im having this same issue but Im rooted. When i go to the verizon store they say they cant give me a new SIM card because my device is rooted and is not compatible and they won't be able to activate it (but yet I was able to activate it over the air with the new rom I've installed). Has anyone else that had this problem with a rooted phone and were able to get a new SIM?
  1. Verizon reps are lost about the G2
    By the1m.polo in forum LG G2
    Last Post: 09-14-2013, 10:51 PM
  2. Replies: 1
    Last Post: 09-14-2013, 08:40 PM
  3. Replies: 21
    Last Post: 09-14-2013, 09:14 AM
  4. Photos Auto Uploading to FB
    By adeath in forum HTC One M7
    Last Post: 09-14-2013, 01:54 AM
  5. Unable to Install ES File Manager via Play Store
    By Chirag Vora in forum General Help and How To
    Last Post: 09-13-2013, 11:58 AM
