1. allongo's Avatar
    Anyone having trouble with Netflix on their g2? I have unlimited data and stream a lot of Netflix to my tv. It always worked great with my razr maxx. But on the g2 it starts to play and the video freezes
    And the audio just keeps on. Frozen picture with sound. Reinstalled Netflix a few times it was the samr story. Was on phone for and hour with Netflix, after much research they said the razor maxed picked up a stronger signal than the g2. I hate to take this phone back but I love Netflix. Will try and take it to an area with stronger signal. I usually have 3 bars on signal meter an a 4g connection. Any ideas?
    09-16-2013 10:42 PM
  2. Umass021's Avatar
    What are you using to hook up to the TV?
    Sent from my A500 using AC Forums mobile app
    09-16-2013 10:57 PM
  3. DroidDev's Avatar
    No trouble here. Just watched 3 episodes of breaking bad on my G2.
    Sent from my VS980 4G using Tapatalk 2
    09-16-2013 11:11 PM
  4. allongo's Avatar
    I am using netgear push to tv. Ptv3000. But it does the same thing when I try to watch it on the phone screen.
    09-17-2013 12:06 AM
  5. jawcaw's Avatar
    Same issue on my new g2. Tried loading older version and same results. Video consistently hangs after a few seconds and audio continues. Frustrating with such a sweet device to not have Netflix working. Previous galaxy nexus running 3.0.2 works fine. Fails on wi-fi and 4g.
    12-22-2013 08:53 PM
  6. jawcaw's Avatar
    Hey folks, still playing with settings and tried turning off the smart screen and smart video settings and now my Netflix is back to working! It would be nice to have those options active but better to just be able to use Netflix again. Give it a try.
    12-22-2013 11:06 PM
  7. akidmtco's Avatar
    I had this problem with my old phone (Moto Photon 4g). The fix I found was to turn Netflix steaming quality to low via the desktop site - account/playback settings.
    Sent from my LG-LS980 using Tapatalk
    12-23-2013 02:49 PM
  8. Adrian Estrada's Avatar
    Ive had this problem for 3 months now. I was at the point of taking my phone back. I've already researched this problem on multiple fourms and sites. Called netflix. Finally, i went to the settings, display, and checked aspect ratio correction and unchecked netflix and it worked 100%
    Hope this helped.
    mostlywords likes this.
    02-07-2014 12:16 PM
  9. sunshynjunky's Avatar
    "Ive had this problem for 3 months now. I was at the point of taking my phone back. I've already researched this problem on multiple fourms and sites. Called netflix. Finally, i went to the settings, display, and checked aspect ratio correction and unchecked netflix and it worked 100%"
    I was having the same problem. Very frustrating. Just unchecked aspect ratio correction and Netflix works fine now.
    Looks like their "correction" isn't much of a correction.
    02-08-2014 09:14 AM
  10. mostlywords's Avatar
    Hope this helped.
    Had this same problem. Applied your "fix", now it works. Thanks!
    02-16-2014 04:19 AM
  11. TomBarrister's Avatar
    I wonder how KitKat users are fixing this problem. LG removed Aspect Ratio Correction from the KitKat release.
    04-20-2014 12:17 AM
  1. wakelock problems
    By thebrain73 in forum Motorola Droid MAXX
    Last Post: 10-07-2013, 02:25 AM
  2. Replies: 1
    Last Post: 09-17-2013, 06:46 PM
  3. Problem with the Stocks application
    By JohnC#AC in forum HTC One M7
    Last Post: 09-17-2013, 08:21 AM
  4. keyboard problem
    By alanwk in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-16-2013, 07:35 PM
  5. Moto x Netflix blue tooth headset
    By asylvia in forum Moto X (2013)
    Last Post: 09-16-2013, 06:52 PM
