Since the battery is not removable, I was wondering what is the best plan in order to maximize the life of the battery?
Does how much the battery drain before charging matter? (Should I let the battery drain as much as I can before recharging, or should I recharge or have it on a charger as much as possible, or does it not matter?) FYI, I could keep it on a charger much of the day during the week - it that good for the battery or not?
Is fast charging (with the stock charger) or slow charging (with an older less-amperage charger) better, or does it not matter?
Thanks!
Thanks!
