Results 1 to 14 of 14
    Default Notifications volume stuck on silent?
    As far as I know, the volume for notifications has is stuck on silent. I can't get it off silent? I have verified that both the stock messaging app and chomp sms are both set for sound, even though the stock app's notifications is diabled. Everywhere you can adjust the notifications volume, I've set to play sounds upon receiving a message. But still, in the system settings, the Notifications volume slider remains on silent and it doesn't respond to touch. all the other sound sliders work fine and I can move them from silent to max volume. WTF!
    anyone have any ideas?
  2. #2
    Klotar's Avatar
    Posts
    Global Posts
    606 Global Posts
    Default Re: Notifications volume stuck on silent?
    No insult intended here but worth a shot: is the device set on Mute? (speaker icon with a line through it, on the notification bar).
    I just did a quick test, if the device is on Mute, the volume slider bars don't work.
    No worries, I'm willing to be insulted if it means I figure this out! yeah, I've made sure it's not on mute... unless there is somewhere hidden I haven't seen yet. to be thorough, when I receive a text, I get the little sms icon in the notifications bar, and the led blinks, but no sound.
    Here is where I've gone to look for some option I might have selected mute or silence:
    system settings -> Sound Tab -> Sound Profile -> made sure "sound' is selected.
    system settings -> Sound Tab -> Volumes -> Here I can see all volume sliders, the Notifications slider is on mute and greyed out and (line through exclamation point)
    Notifications bar quick toggles -> sound toggle is set on "Sound."
    I've gone into both the stock messenger and Chomp SMS that I use and see nowhere to turn the sound off.
    I haven't found anywhere else that will allow me to fix this... am I missing something any of you know of??????
    thanks!
    Nevermind... I just restarted the phone and the notification slider is now working. So I guess this is a "is your computer plugged in" tech support moment.
  5. #5
    bespinct's Avatar
    Posts
    Global Posts
    853 Global Posts
    Carrier
    Stock!
    Quote Originally Posted by Mike Gonzales View Post
    Is amazing that so many years later, a reboot often addresses the problem. Glad to see the issue resolved so simply.
  6. #6
    I had the same problem this morning and could not figure out what was happening. I restarted the phone several times, switched the profile to "sound" only to have it revert back to "silent" within seconds. I finally figured out that my AT&T Drive Mode app was activated, despite the fact that it should only auto-activate when I'm traveling at 25 mph or greater, and I was sitting calmly in my bed at the time, with my phone beside me on the nightstand. Once I disabled Drive Mode, I was able to change the sound profile normally. I'm not sure if this has been an issue for others, but I thought I would post just in case.
    ScottsoNJ likes this.
  7. #7
    this isn't a fix, but I'm pretty sure the problem is the new OS update. I've never had a problem and now it's a couple of bugs here and there since.
    Android! Fix kit Kat!
  8. #8
    I'm having the same problem all of the sudden and I've gone through every possible place to try and adjust! This is annnnnnooooyyyyyiiiiinnnnngggg!
  9. #9
    I have the exact same issue but on a G3. A reboot temporarily fixes it as well. I do have CarHome Ultra and Tasker which can mess with volumes....haven't dug too far into those yet. I haven't changed anything there so I don't know why this would start doing this all of a sudden.
  10. #10
    The "Turn Off All Sounds" option can be accessed via Settings > Accessibility. Scroll down in Accessibility. Uncheck it.
  11. #11
    Quote Originally Posted by VicWheeler View Post
    So I have the same issue. My volume turns off on its own, except that when I turn volume up my phone downloads random apps
  12. #12
    I restarted my phone, made sure nothing was on mute, I shut down every running app but what ended up working for me was going to System Settings> Sounds & Notifications> Sound Profile and selecting "Silent". That seemed to restore normal function. I could not put my phone on silent through the status bar. And all my volumes were grayed out as well. I was able to put it on "vibrate" and "sound" but not "Silent".until I did it through the sound profile
  13. #13
    Quote Originally Posted by Beer wolf ab View Post
    I signed up just to thank you, because your explanation solved the same problem for my G2. Trying to turn off quiet mode seemed to make my phone hang, overheat and become unresponsive (black screen eventually)... No idea what was happening.
  14. #14
    My Kindle Fire may be similar. In my case the systems and notifications volume in settings was grayed out because the quick settings panel was set to 'do not disturb', and this was enough to eliminate hearing conversations on Skype or even the camera shutter.
  1. Replies: 28
    Last Post: 01-12-2017, 09:15 PM
  2. my galaxy note won't turn on
    By Nurul Rubyy in forum Samsung Galaxy Note
    Last Post: 02-21-2016, 04:39 PM
  3. Can't see fullscreen video when casting a Chrome browser tab.
    By Chris Dodge in forum Google Chromecast
    Last Post: 07-10-2015, 04:00 AM
  4. I am having issues installing Flash Player on my Note 3
    By MrClarenceCat in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-27-2013, 09:38 AM
  5. Replies: 3
    Last Post: 10-17-2013, 09:58 PM
