1. acehjo's Avatar
    Anyone else have this problem :
    when leaving my home (and wifi network) the phone doesn't automatically switch to mobile data service. The only way i can get it to work is to go to tethering/networks/mobile networks and switch the "UMTS/LTE automatic" mode off and back on.
    Any solutions, suggestions ?
    thx
    11-04-2013 04:00 PM
  2. legas86's Avatar
    Same issue here.. any solutions?
    thx
    11-29-2013 02:03 AM
  3. Dpsavino's Avatar
    Have the same problem. Im using car home ultra to turn wifi off when my phone auto connects to car bluetooth. Not the perfect solution but works for me
    11-29-2013 03:13 PM
  4. Kdroid's Avatar
    I'm not having this issue with the Verizon version. When I'm out of range for the wireless network it automatically switches to data/mobile mode and returns to wifi when back in range.
    12-03-2013 05:30 PM
  5. David Meulemans's Avatar
    thx
    - - - Updated - - -
    Same here
    12-27-2013 03:01 PM
  6. VonSohn's Avatar
    I got that same problem solved after the latest update for my international G2. I used to turn on and then off the airplane mode when that happened. I know, nothing fancy, but it worked. Again, an update should fix it for you.
    Sent from my LG-D802 using Tapatalk
    12-27-2013 05:12 PM
  1. New System Update...Cant move Apps to SD card anymore
    By justrelaxing in forum General Help and How To
    Last Post: 01-06-2014, 11:30 PM
  2. Slamming the LG G2 in favor of the Ultra
    By MikeLip in forum Motorola Droid Ultra
    Last Post: 12-02-2013, 02:18 PM
  3. Soak Test Reboot problems on Rooted maxx
    By goliatham in forum Droid MAXX Rooting, ROMs, & Hacks
    Last Post: 11-11-2013, 11:47 PM
  4. Optimus LG L7ii specifications.
    By stalemate1 in forum LG Optimus L
    Last Post: 11-05-2013, 09:01 AM
  5. Porting galaxy note 3 and 10.1 features to other android devices?
    By aaka3207 in forum General News & Discussion
    Last Post: 11-05-2013, 08:58 AM
