1. johnnyshinta's Avatar
    I was using my phone's screen to find my way in the dark and i ended up holding my phone in front of our cold air humidifier for a few seconds. Would that be enough for moisture to enter the phone and cause damage?
    11-08-2013 08:44 AM
  2. OhAlfie's Avatar
    Nope
    11-08-2013 08:46 AM
  3. johnnyshinta's Avatar
    After posting this I spoke to my friend that has a galaxy s4. He apparently leaves his phone on the bathroom counter while he showers and has had no ill effects.
    11-08-2013 09:25 AM
  4. streetkilln's Avatar
    Water on the screen or backside wont harm it unless water goes straight into the ports then 50 50 chance there will be an issue
    Sent from my LG-D800 using Tapatalk
    11-09-2013 05:17 AM
  5. johnnyshinta's Avatar
    I was concerned because the mist may have been hitting the ear piece up top.
    11-09-2013 08:53 AM
  6. BecomingDeath13's Avatar
    You should download a flashlight app. It'll activate your camera flash so you can see that way. Your phone would also be less exposed to taking in moisture. Not to mention it would also be brighter.
    Posted From My Sprint Samsung Nexus S via Android Central App
    11-16-2013 05:06 PM
  7. Just_Some_Nobody's Avatar
    There's a flashlight app included with the AT&T version.
    Posted via Android Central App using an LG G2.
    11-17-2013 06:52 AM
  8. donm527#IM's Avatar
    Widget. when you wrote that i didnt remember seeing an app... but then saw a flash widget. interesting find.
    11-17-2013 08:42 AM
  9. Just_Some_Nobody's Avatar
    Thanks for the correction.
    11-18-2013 07:56 PM
  1. Replies: 4
    Last Post: 11-11-2013, 01:04 PM
  2. Galaxy Gear working after being submerged in water.
    By AldousSnow in forum Samsung Galaxy Gear
    Last Post: 11-09-2013, 11:31 PM
  3. Galaxy Gear working after being submerged in water.
    By AldousSnow in forum Samsung Galaxy Note 3
    Last Post: 11-09-2013, 02:52 PM
  4. Absolute best Android phone camera?
    By jdevenberg in forum General News & Discussion
    Last Post: 11-08-2013, 09:45 PM
  5. how to remove writings on the back of Nexus 5
    By cephas in forum Google Nexus 5
    Last Post: 11-08-2013, 07:55 AM
