There has to be a thread for skins. Wilsl explore.
Thanks.
Sent from my LG-D800
Xtreme Guard is having a sale 85% off their skins. I bought it over Christmas sales. A bunch of screen protector for LG g2 and wife ipad few just a few bucks!
It cheap for a reason. No fancy packaging. They were mail in white envelopes. Plus you need to make your own when solution, which is simply water and a single drop of dish soap. Use a credit card for a squeegee.
I put them on fine on both devices. The I did get a speck of dust on my wife ipad. Got it off but scratch off a bit of the tackiness and I couldn't get it off with tape. Made it noticeable when on. So I simply took it off and applied another protector.
Given how Inexpensive they were I had no problem buying a bunch for that occasion.
Worth a try at such little cost for you.
Sent from my LG-D800 using Tapatalk
