Hello,
I have my lg g2 for almost a week and my bro also has it . On my G2 as I attached the screen shots in the battery usage shows the android system used 54% and this is too high even more than the screen, but my brother G2 its not like this. I want to know is it normal or not? I have only 3 days to return it, should I return it?
I am on Sprint network. all the location access is off. i don't use google + , hangout and any other google services except google play. I have only one email that use to sync my contacts. GPS, NFS and Bluetooth (Just used BT to send the screen shots to my computer) are always off.
Thanks
Thanks
