1. cajunbeast's Avatar
    I just rooted my Verizon LG G2 and I'm wanting to Flash a recovery so I can start flashing roms. I have the TWRP Image but every time I try to Flash using flashify it just reboots with the LG logo and goes blank. I'm on the latest update VS98012B.
    01-11-2014 01:47 PM
  2. Bdrago86's Avatar
    I'm having the same exact problem and it's got me livid at this point. I have tried both teamwin and cwm with the same results.
    01-12-2014 05:29 PM
  3. greyhd's Avatar
    How did you root your phone? Did you try to install twrp using add?
    Sent from my VS980 4G using Tapatalk
    01-12-2014 07:32 PM
  4. cajunbeast's Avatar
    I rooted with ioroot. It didn't come with recovery. I tried flashing the TWRP Image via flashify app. I also downloaded the TWRP app and it says not available for g2.
    01-12-2014 08:18 PM
  5. sp44's Avatar
    Try FreeGee app.
    cajunbeast likes this.
    01-12-2014 08:21 PM
  6. cajunbeast's Avatar
    I just downloaded it. Gonna give it a try! Thanks.
    01-12-2014 08:24 PM
  7. greyhd's Avatar
    I loaded twrp via adb and it was pretty simple.
    01-13-2014 12:51 AM
  8. SactoKingsFan's Avatar
    Have you tried CWM? It's pretty easy and works like TWRP just with different UI.
    01-13-2014 01:08 AM
  9. Bdrago86's Avatar
    I found that app Freegee earlier and used it. It let me get into both recoveries. The problem im having now is that TWRP fails when i try to flash CM 10.2 and CWM freezes on wiping/cache while doing a factory reset before i try to install CM 10.2
    01-13-2014 01:22 AM
  10. cajunbeast's Avatar
    I was able to get Into recovery and do a backup. Dumb question... This is my first time flashing roms without an SD card. Will doing a factory data reset wipe my Internal storage?
    01-13-2014 09:01 AM
  11. SactoKingsFan's Avatar
    http://teamw.in/whattowipe
    Sent from my rooted LG-G2 using Tapatalk
    01-13-2014 09:20 PM
  12. Michael Khu's Avatar
    im having the same problem it goes blank after booting to recovery using twrp, how did you fix it? please reply
    01-14-2014 03:45 PM
  13. Michael Khu's Avatar
    how did you fix it? im having the same problem it goes blank after booting to recovery using twrp, how did you fix it? please reply
    01-14-2014 04:33 PM
  14. itsmilly's Avatar
    Auto rec worked for me -took about 5 seconds. LG g2 vs980
    07-20-2014 11:48 PM
  15. cody rafferty1's Avatar
    Im on ls980 zvg ( lollipop) just rooted with lg one click and ive tried all apks for flashing recoveries and cant get one to properly take to the phone i always get the error. Im not fiding any other info. Need help and no pc to go the adb way...
    06-25-2016 07:24 PM
  1. Help, broken samsung galaxy s3 dropped in clean water
    By androidashlea in forum AT&T Galaxy S III
    Last Post: 02-06-2014, 09:42 PM
  2. Screen and applications freeze randomly after recent update
    By Vanamali C Shastry in forum Samsung Galaxy Mega 5.8
    Last Post: 01-31-2014, 01:18 AM
  3. Replies: 4
    Last Post: 01-13-2014, 08:09 AM
  4. Help With Nexus 7 (2012) Bootloop Issue :(
    By Clare K1 in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-12-2014, 11:12 AM
