Results 1 to 13 of 13
    Default LG G2 - Newly rooted and can't flash recovery... HELP!
    I just rooted my Verizon LG G2 and I'm wanting to Flash a recovery so I can start flashing roms. I have the TWRP Image but every time I try to Flash using flashify it just reboots with the LG logo and goes blank. I'm on the latest update VS98012B.
  2. #2
    Default Re: LG G2 - Newly rooted and can't flash recovery... HELP!
    I'm having the same exact problem and it's got me livid at this point. I have tried both teamwin and cwm with the same results.
  3. #3
    greyhd's Avatar
    Posts
    Global Posts
    646 Global Posts
    How did you root your phone? Did you try to install twrp using add?
    Sent from my VS980 4G using Tapatalk
    I rooted with ioroot. It didn't come with recovery. I tried flashing the TWRP Image via flashify app. I also downloaded the TWRP app and it says not available for g2.
  5. #5
    sp44's Avatar
    Posts
    Global Posts
    69 Global Posts
    Try FreeGee app.
    Thanked by:
    I just downloaded it. Gonna give it a try! Thanks.
  7. #7
    greyhd's Avatar
    Posts
    Global Posts
    646 Global Posts
    I loaded twrp via adb and it was pretty simple.
  8. #8
    Have you tried CWM? It's pretty easy and works like TWRP just with different UI.
  9. #9
    I found that app Freegee earlier and used it. It let me get into both recoveries. The problem im having now is that TWRP fails when i try to flash CM 10.2 and CWM freezes on wiping/cache while doing a factory reset before i try to install CM 10.2
  10. Thread Author  Thread Author    #10
    Default
    I was able to get Into recovery and do a backup. Dumb question... This is my first time flashing roms without an SD card. Will doing a factory data reset wipe my Internal storage?
  11. #11
    Quote Originally Posted by cajunbeast View Post
    Sent from my rooted LG-G2 using Tapatalk
  12. #12
    im having the same problem it goes blank after booting to recovery using twrp, how did you fix it? please reply
  13. #13
    how did you fix it? im having the same problem it goes blank after booting to recovery using twrp, how did you fix it? please reply
  1. Help, broken samsung galaxy s3 dropped in clean water
    By androidashlea in forum AT&T Galaxy S3
    Last Post: 02-06-2014, 09:42 PM
  2. Screen and applications freeze randomly after recent update
    By Vanamali C Shastry in forum Samsung Galaxy Mega 5.8
    Last Post: 01-31-2014, 01:18 AM
  3. Replies: 4
    Last Post: 01-13-2014, 08:09 AM
  4. Help With Nexus 7 (2012) Bootloop Issue :(
    By Clare K1 in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-12-2014, 11:12 AM
  5. [FREE] Fruits and Veg for Kids
    By pramoth_rj in forum Android Applications
    Last Post: 01-12-2014, 10:05 AM
B
