Results 1 to 7 of 7
    Default Notification LED frequency
    I just got my G2 yesterday. I like it a lot so far, but one thing I was wondering is whether the frequency of the notification LED can be changed. It seems like the LED flashes really slowly, especially compared to the other phones I have previously used. I couldn't find a way to change it in the settings, so is there some way to make it flash faster?
  2. #2
    Klotar's Avatar
    Posts
    Global Posts
    606 Global Posts
    Default Re: Notification LED frequency
    In a word, no.
    That said, there are apps out there, such as Light Flow, with which you can change the flash frequency. I would mention Light Manager but it requires root for 4.2 in order to support most non-native apps.
    Possibly also, you can root and there may be roms/mods out there that may allow you to do this. I just use Light Flow.
  3. #3
    VW Maverick's Avatar
    Posts
    Carrier
    Nitrogen OS 7.1.1 Nougat
    GO SMS allows you to change the color and speed of the LED on incoming text messages.
    Works on the Sprint version.
    Mav.
  4. #4
    Quote Originally Posted by VW Maverick View Post
    Mav.
    The only downfall to that is you have to use GoSMS. ;-)
    Sent from my LG-LS980 using AC Forums mobile app
  5. #5
    Posts
    Carrier
    Quote Originally Posted by Mikey47 View Post
    I know, right?
    Actually I have had no problems with GO's SMS app. Not sure what people don't like about it.
    Oh well. That is why there are a Million and 6 other SMS apps out there.
    Mav.
  6. #6
    I know, right?
    Mav.
    I got tired of their trying to be everything to everyone and constant updates with things I would never use.
    I switched to Chomp, but with my g2 I've just been using the default messaging app.
  7. #7
    Quote Originally Posted by hallmr09 View Post
    I also recommend LightFlow. You can change the brightness, the light colour, and the rate and duration of flashing. You can even allow it to be your central notification hub, effectively, because it can also control the audio and vibration of each app
  1. Notifications
    By joeco23 in forum Samsung Galaxy S4
    Last Post: 01-20-2014, 03:20 AM
  2. Replies: 4
    Last Post: 01-15-2014, 10:15 PM
  3. I have an update notification, but can't update
    By Pj Gutierrez in forum T-Mobile Galaxy S3
    Last Post: 01-15-2014, 11:01 AM
  4. Replies: 4
    Last Post: 01-15-2014, 08:47 AM
  5. Default synchronize dismissed notifications
    By boneyard in forum General Help and How To
    Last Post: 01-15-2014, 06:18 AM
