Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Like Tree2Likes
    Brandon Shea's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default LG G2: problem when flashing customROM 4.4 AOSP
    Hey guys!!
    So, i'll just dig right in I guess. Firstly, i'm asking here 'cuz frankly the people at XDA can be kind of...rude about things, and you guys have been GREAT to me so far.
    so, Heres my sitaution. I have a g2 d803, telus canada.
    running stock, rooted.
    I tried to flash Paranoid android 4.4.2 ([AOSPA 4.4.2 KOT49H] PARANOIDANDROID 4.0+ G2 [beta4][02/05] - xda-developers) On it using the D803 link of course. It didn't work. I keep getting FAILED.
    I wiped system/dalvik/cache/data, tried beta 4 and 5. I downloaded GAPPs. I am on the current twrp, I think? not sure how to check.
    I get this error every time, on both rom versions:
    " Checking for MD5 file...
    Skipping Md5 check:no MD5 file found.
    verifying zip signature.....
    set_metadata_recursive:some filesfailed "
    Considering this has happened on 2 betas, and no one else in the thread is saying this is happening, i'm really confused. ( I can't post there cuz i don't have 20 posts in xda, so i can't post in the dev section. lol )
    Are you guys familiar with whats going on here?
    appreciate any help thrown my way. Thanks all.
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: problem when flashing customROM 4.4 AOSP
    Hello,
    Not having the LG G2 I can't address the issue completely. But I can try to narrow down a few things.
    Latest TWRP recovery, go to TeamWin Projects - TWRP 2.6 - | TeamWin to check the official list of supported devices. Latest CWM, go to ClockworkMod ROM Manager - Recoveries to check the official supported list there. If the device isn't officially supported I would recommend changing your recovery to whichever developer " officially " supports it.
    Failing on the MD5 check. You can change the settings from either recovery to ignore/skip the MD5 check and see if that gets it flashed. Sure the MD5 is there for a reason but if you feel confident that its been a good & complete download then you can skip this process. All its basically doing is verifying that your download file size, etc matches the same as what is on the server.
    Finally I get what your saying about the crowd being a bit " rough " at other forums. You won't get that type of treatment here
    Hopefully some other more experienced LG G2 members can jump on this thread and give you a hand.
    Paul
    Moderator Team Leader @ Android Central.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks paul. So, the latest twrp for bell is 2013,so i definitely have the newest one.there is a 'forget md5 on back up files' in the settings but is that just for my recovery or no?
    Thanks for the kind words.
    Sent from my LG-D803 using Tapatalk
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Brandon Shea View Post
    I think you mentioned this in the other forum, but just making sure. Before you flash the ROM with TWRP, there should be a small box for checking/unchecking MD5 file verification. Can't get a screenshot from recovery so I can't show you exactly what it looks like.
    Brandon Shea likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I seen zip signature verification but no md5 bypass? I would'vr tried it had i seen it. Hmm, maybe its a new twrp feature and im not updated?
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Just booted into recovery and you're correct, it is zip signature verification. Sorry about that
    Is there a specific feature about Paranoid Android you like or would you be willing to try another ROM and see if this is an isolated issue with PA?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nah, any aosp rom im okay with. I just want the 'nexus 5' experience, haha. I was told PA was the best is all.
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    That's a first lol
    I've tried out CM and SlimKat, the latter is better by far.
    I'm pretty sure they support the G2 as well. The Kit Kat version is still in Beta, but it was stable from my limited use with it. 4.3 has two official builds if you don't mind being a little behind
    Slimroms.net has a list of supported devices
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also my big thing is finding a rom with d803 support cuz i dont know how flash kernels or anything. Other than that any d803 4.4.2 rom is fine with me!
  10. #10
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Doesn't look like it's supported by Slim
    Cyanogen Mod isn't a bad option either and I have heard some good stuff about Omni ROM.
  11. Thread Author  Thread Author    #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks uj, ill check it out tonight. Off to work for 8 hours. Thanks again man
  12. #12
    GibMcFragger's Avatar
    Posts
    Global Posts
    1,929 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can flash pretty well any D802 rom (as far as i know), provided you flash a d803 compatible kernel IMMEDIATELY AFTER (before you reboot).
  13. Thread Author  Thread Author    #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I dont know how to do that gib.. If you could help id appreciate it.
  14. #14
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    You flash it the same way you would the GApps or the ROM. Before swiping to confirm, hit "add more zips" and look for the kernel.
    I usually avoid ported ROMs to prevent any possible issues. Stick to model specific ROMs
  15. Thread Author  Thread Author    #15
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Update: just had to use the new twrp. Mine wasn't updated all the way, Opps. Thanks for all the info boys. I'm enjoying PA AOSP!
    GibMcFragger likes this.
  16. #16
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Cool. Sole ROMs work with only a certain version of the recovery. Glad you got it running
  17. #17
    vulpid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: LG G2: problem when flashing customROM 4.4 AOSP
    I installed twrp the most updated version but I still fail when I flash Paranoid Android. How did you get yours to work.
  18. Thread Author  Thread Author    #18
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you enable zip verification?
  19. #19
    vulpid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    where is that?
  20. Thread Author  Thread Author    #20
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Should be right above the flash button
  21. #21
    vulpid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i will try again enabling. will update after. Thank you for help, been trying to get PA on my g2 all day.
  22. Thread Author  Thread Author    #22
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No problem man, get back to me. I went through the same thing so I'm down to help in any way I can
  23. #23
    vulpid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I enabled zip verification and re-flashed. It fails again.I noticed it says no md5 file found.
  24. Thread Author  Thread Author    #24
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the Same problem, my twrp wasn't up to date even though I thought it was. What version are you running?
  25. #25
    vulpid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    rogers twrp v2.6.3.2
  1. When did the $10 Google Play Credit end?
    By Cozume in forum Moto X (2013)
    Last Post: 08-06-2014, 10:18 PM
  2. so what happens when battery dies in two or three years?
    By robbielyn in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-22-2014, 10:16 PM
  3. Problems with speaker
    By Taadis Markevicius in forum Samsung Galaxy S4
    Last Post: 02-07-2014, 08:16 PM
  4. Replies: 5
    Last Post: 02-07-2014, 02:05 PM
  5. Battery drop when not in use.
    By P5YDEX in forum Samsung Galaxy S II
    Last Post: 02-07-2014, 01:58 AM
