Results 1 to 4 of 4
    Default UK LG G2 - how do I set up wireless charging in the UK
    I live in the UK - I have my new LG G2, how do I set up wireless charging? have they released a case I have to attach first?
    Many thanks,
    Jack.
  2. #2
    Default Re: UK LG G2 - how do I set up wireless charging in the UK
    It's not built in, and as far as I know, they haven't built a case that will allow you to do it.
  3. #3
    Klotar's Avatar
    Posts
    Global Posts
    606 Global Posts
    I bought one of these below, and then got a charging pad:
    Type A Micro USB QI Wireless Universal Charger TAG Receiver Coil FOR LG G2 NEW | eBay
    Note: unlike true wireless charging devices (no coil needed) or wireless charging "ready devices" (just add a coil), this solution uses your G2's USB port. That means, no Quick Charge using cable (you don't want to be constantly disconnecting and reconnecting the coil/cable), and file transfers/sync need to be wireless. Because the G2's battery is so good, I don't need to Quick Charge, as it will fully charge overnight wirelessly, and with G2's Wireless Storage applet, all my file transfer needs are taken care of with that and Dropbox. You do need a cover for the G2 but I use one anyway.
    lutin likes this.
    Ok, thanks both for the reply. I will have a look into that charger TAG if I get a case like the look of the Quick View cases.
    Cheers.
  1. Galaxy Tab Pro 8.4: Will they have the 32 gb soon?
    By athenatp in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 05-31-2014, 12:23 PM
  2. Help!!!! My screen resolution is messed up!!
    By sberry11 in forum Samsung Galaxy Note 2
    Last Post: 02-14-2014, 01:05 AM
  3. NO COMMAND when starting up
    By Garry Reeves in forum ASUS EeePad MeMo
    Last Post: 02-13-2014, 10:44 AM
  4. Flappy Brid - The Movie
    By Huckbros in forum Android Apps
    Last Post: 02-13-2014, 06:02 AM
  5. Looking for the right rom, help please.
    By King Hayve in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-13-2014, 04:16 AM
