1. Jayme Koerselman's Avatar
    I'm having a real issue with my unlocked LG G2 microphone. My microphone seems to be not working I think as the voice search (google) and any app using a mic (voice recording) and videos isn't working or crashes when I try to record. I've done two things that I think might have changed this. I updated the software version a week or so back and it seems to not have worked since. I also installed a Spanish learning app duolingo which at points I didn't want to use the voice input questions and there was an option to "turn it off" which seemed to then "turn the microphone off" for an 'hour' until it was supposed to come back on. I've deleated the app to no avail and restarted a couple of times. I'm not sure how to access the "microphone" on any of the settings. Any help would be much appreciated. Thanks.
    02-17-2014 01:59 AM
  2. iamnow's Avatar
    Using the same phone (LG G2 KitKat) parties can NOT hear my voice, unless I turn on the speaker phone. Is this a bad internal microphone or some app or settings issue? Can somebody help me with this frustration.
    03-23-2014 10:08 PM
  3. anon5658834's Avatar
    Try turning off noise suppression in call settings
    03-23-2014 10:30 PM
  4. bellshirado's Avatar
    I don't see a noise suppression option on the LG G2. Where in settings is it located?
    03-24-2014 01:57 PM
  5. Marcolav's Avatar
    I have the same problem. I also did a factory reset, but my voice is still low using the microphone (not with headset or speaker)
    03-26-2014 06:45 AM
  6. bellshirado's Avatar
    Talked with T-Mobile and they suggested using a simple compressed air can to clean out the speaker port. Now I am heard much more clearly.
    03-26-2014 01:54 PM
  7. Marcolav's Avatar
    I removed the noise reduction and now it's much better, but there is still a huge difference with the headset mode.
    I read this could be a software problem, solvable with a custom rom: what do you think? The last post by bellshirado suggests it's a hardware problem instead
    03-27-2014 06:32 AM
  8. Mikey47's Avatar
    Compressed air is the duct tape of cell phones. Had a problem with my wife's G2 charging super slow (with a charger that charges mine super fast). Turns out it was dust/lint in her charging port. A little compressed air and she was back to fast charging!
    Sent from my LG-LS980 using AC Forums mobile app
    Marcolav likes this.
    03-28-2014 07:23 PM
  9. Atrader1's Avatar
    Bought my Verizon LG G2 4 week ago and am on my 3rd phone due to microphone issues. Everyone I talk to says my voice fades in and out and is very hard to hear. Called Verizon they say I can replace with a different make and LG says to send it in for service. 3 phones and they all do the same thing its a manufacturer problem!! Speaker phone works great. Any fixes for this out there?
    03-30-2014 05:00 PM
  10. Marcolav's Avatar
    No one for me, I sent it back for service as well...
    04-02-2014 08:53 AM
  11. Srikanth Raj's Avatar
    Did you find a solution for headset mic problem? let me know
    06-07-2014 04:33 PM
  12. jackswindle's Avatar
    I have the same microphone problem as everyone else with the LG GE. I'm nearly positive its a software issue regarding noise canceling. I kind of found a work around. First i turned off noise suppression in call setting. Then I plugged the top microphone hole on the phone as well as plugged the hole in my phones case. People can hear me WAY better now. I tested it with my gf using my phone, covering the hole with her finger and without while speaking. Her voice would go in and out. I'm guessing the phone is confusing us talking with ambient noise or something.
    06-07-2014 11:28 PM
  13. dorian540's Avatar
    I have an LG P705 and the mic has stopped working except when on speaker phone.
    Have tried cleaning mic. Have not been able to find noise cancelling in phone settings. Could the problem be that I downloaded Whatsapp recently? Any suggested cures for my phone mic?
    John Burrows likes this.
    06-17-2014 05:14 AM
  14. John Burrows's Avatar
    01-12-2015 03:35 AM
  15. Droid Xcathedra's Avatar
    I was super annoyed because the stock Voice Recorder app (G2) wouldn't work ("In use by another app.") I uninstalled Duolingo and now VR works. Yaaaay.
    02-04-2015 05:31 AM
  16. Edy Mishra's Avatar
    where is noise suppression in call settings ??
    I couldn't find it
    03-14-2015 12:57 PM
  17. Karolis Janonis's Avatar
    If you are using some apps like go launcher or other like that, it canmake some problems like that, that was for me too
    03-15-2015 03:13 PM
  18. mrmiking's Avatar
    I cant see anywhere to turn off the Noise Suppression in call settings either, any help?
    09-16-2015 10:43 AM
  19. SnorkieDog's Avatar
    Settings - Networks tab - Call - Noise Suppression checkbox
    10-09-2015 03:23 PM
  20. Nagendra Prasad1's Avatar
    Hi,
    Is that ur issuse of microphone not working is resoved..
    I am facing the same problem..
    Please share me the various methods u used to reslove this issue..
    Thanks in Advance...
    11-11-2015 08:04 AM
  21. marioval's Avatar
    I'm actually having the opposite problem, if I use the phone normally for a call (hold it up to my ear) then all works as expected. If I switch to speaker phone the other side can not hear me. I tried noise Suppression on and off, I even did a factory reset but no success.
    01-31-2016 06:20 PM
  22. Labore's Avatar
    Hi,
    I´ve tried all recomended procedure (updating newer software / OS, deactivating noise reduction, checked the main mic function in service mode using mic loopback - OK). Now I´ve tried to deactivate upper noise microphone by putting a bit of adhesive tape over its pine hole. It seems the phone works now much better.
    02-16-2016 12:25 AM
  23. DIY-girl's Avatar
    I got the same problem. My LG G4 phone didn't work. When I answering the phone people seem can't hear me like i'm speaking from a distance. After I read a solution in here. I've try used a stright pin to clean the tiny hole next to my head set hole. I clean out a small dirt. Then I try to check my microphon by using a voice recorder. And it actually work! Phew! I nearly set my phone back to a factory setting to solve this issue. (not sure it would work thought ;-p)Thank you so much. xxx
    09-03-2016 01:40 AM
  24. Alextayloralextaylor's Avatar
    I have duolingo and the mic thing just means the verbal feedback on app which requires mic wont be enabled fir an hour, thats only limited to the app, your mic isnt actually being turned off, im pretty sure thats not even possible to turn a mic off
    09-07-2016 02:24 PM
  25. Alextayloralextaylor's Avatar
    Get a pressured air can with a nozzle and get that 8" away from the mic hole and shoot aur at it, itll clean out the hole. I think mine is messed up because u went to beach a while ago and every time i go i always manage to get sand in my devices mic...pressured air fixes all. You can get a can at like home depot or ace or something...
    09-07-2016 02:28 PM
  1. HTC One Turning On Problem [HELP]
    By Armanivers in forum T-Mobile HTC One
    Last Post: 02-23-2014, 09:30 AM
  2. problem with soft key fademode
    By dave3389 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 02-18-2014, 02:24 PM
  3. Problems sending e-mail
    By cb2367 in forum Sprint Galaxy S III
    Last Post: 02-16-2014, 10:55 PM
  4. Sony Xperia miro Headset problem
    By Black_XIII in forum Sony Xperia Series
    Last Post: 02-16-2014, 10:45 AM
  5. Kindle Payment Method Google Wallet Problems. Help!!!!
    By ashbashbonkfan in forum Samsung Galaxy Note 10.1
    Last Post: 02-16-2014, 08:53 AM
