1. mugenakuma's Avatar
    Just got my G2 and I am unable to find a way to hide the front facing on screen buttons during web browsing. Does anyone know if this can be done without rooting the phone? I sure hope so because browsing with those buttons taking up portions of the viewing area is a drag....
    02-28-2014 01:09 AM
  2. Adanick1's Avatar
    Nope, unfortunately it can't be done without rooting.
    Sent from my LG-D800 using AC Forums mobile app
    02-28-2014 09:32 AM
  3. mugenakuma's Avatar
    Thanks for the reply. :-) I've rooted in the past with no problems but am curious, how difficult is it to root the G2? Any issues I should watch out for? Do you think there are real benefits to rooting, other than being able to have full screen web browsing?
    Any tips or suggestions on how best to root and which KK ROM is best for an AT&T G2? I am sure most of those answers can be found on the forum but i figured i'd ask here. ;-)
    02-28-2014 02:44 PM
  4. liteon163's Avatar
    My LG G2 is the fourth smartphone I've had and by far the easiest to root. I rooted primarily to enable all screen rotations, but I found a couple of Xposed modules that really help the phone work better - G2 TweaksBox and Greenify.
    I could tell you about those modules (G2 Xposed is another one), but you'd be better served by finding out by yourself so you can decide if they would make rooting worth it. Just use Google and the Play Store.
    Sent from my Verizon LG G2 using Tapatalk
    02-28-2014 10:21 PM
  5. SactoKingsFan's Avatar
    The G2 is very easy to root using ioroot. You can unroot by using LG flash tool and flashing stock firmware.
    The benefits of rooting include removing ads (AdFree), flashing ROMs, creating nandroid backup, installing various mods, improved performance, and completely controlling app permissions.
    Sent from my LG-G2 running CMB 4.4.2
    03-01-2014 04:41 AM
  6. mugenakuma's Avatar
    Thanks for all your thoughts on this. I definitely will be rooting. Hopefully it won't be too difficult now that I'm running KK. I did see a thread on xda forum about how to root with a KK G2 so wish me luck. ;-)
    03-02-2014 01:14 AM
  1. The Note 3 "S Pen"
    By BoroughChild in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 09-29-2014, 05:22 PM
  2. [FREE] Floppy Pipe - Flop the pipe instead of bird!
    By EPipol Net in forum Android Games
    Last Post: 03-22-2014, 11:03 PM
  3. How do I mark and copy text on the phone?
    By dart4605 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-02-2014, 08:33 PM
  4. Galaxy Note 10.1: Default On Screen Keyboard
    By monicakm in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-01-2014, 08:10 AM
  5. Hide apps
    By joseatnj in forum Android 4.4 KitKat
    Last Post: 02-28-2014, 10:03 AM
