1. JozayG2's Avatar
    I was wondering if any one out there has purchased a longer micro-USB to use with the plug shipped with the LG G2. I am wary of buying one since I do not want to damage my charger port with a poorly made USB wire
    Thanks
    03-02-2014 10:31 PM
  2. wizzrah's Avatar
    Thanks
    I use an Amazon Basics cable with various devices. It works great.
    Amazon.com : AmazonBasics USB Cable - 2.0 A Male to Micro B (6 Feet / 1.8 Meters) : Computer Usb Cables : Electronics
    JozayG2 likes this.
    03-02-2014 10:45 PM
  3. MissPrettyKitty's Avatar
    I have used ones from various eBay sellers and they've been fine with Sony phones and iPhones. Can't speak for g2 yet as my chord broke the other day and I only just got the g2! But I wouldn't worry about it.
    JozayG2 likes this.
    03-02-2014 10:58 PM
  4. JozayG2's Avatar
    Thanks just been reading the reviews for this some look worrying lol saying things like the microUSB end melted. Have you used it on the G2?
    03-03-2014 09:50 AM
  5. steve daniels's Avatar
    Also...show all reviews, then search for "G2" in the reviews for this product. It doesn't look good.
    JozayG2 likes this.
    03-03-2014 12:20 PM
  6. DaveyXXX's Avatar
    One thing of note is that if you use a cheap or long cable the charger will not be able to do a fast charge as there will be too much voltage drop. After testing a few cables most would only charge at ~500ma or so and would get the "slow charging" warning. I cut off a cable a few inched from either end and spliced it back together with a longer piece of 18ga wire and can charge at ~1200ma with that.
    03-03-2014 05:42 PM
  7. wizzrah's Avatar
    Yep, the longer the cable, the slower the charge. I don't really notice any difference when using the Amazon cable.
    03-03-2014 10:31 PM
  8. JozayG2's Avatar
    I have bought the FRiEQ cable from Amazon it is 6 feet long and it does not give me the slow charging notification when using this wire, 5 star reviews on Amazon heres the link if anyone else is interested http://www.amazon.co.uk/FRiEQ%C2%AE-...cUvbUpU3511471
    03-14-2014 08:29 PM
  1. Galaxy S3 Mini: USB Debugging problem
    By loanaduque in forum Samsung Galaxy S3 Mini
    Last Post: 09-18-2014, 01:33 PM
  2. htc one x charger port problem
    By darlapig in forum HTC One Series
    Last Post: 03-18-2014, 09:21 PM
  3. Charger/Is This Safe for Our GN/2014?
    By monicakm in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-03-2014, 05:13 PM
  4. USB Fast charge mod
    By heinzmoleman in forum Chargers and Batteries
    Last Post: 03-02-2014, 03:28 PM
  5. Helllllpppp. Dropped phone and sent messages no longer showing
    By azevick in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 03-01-2014, 11:19 PM
