Results 1 to 4 of 4
    Default LG G2 battery issue FIX
    Just figured I'd throw this out there for all my fellow G2 users...
    I have noticed that sometimes if I let my battery get below 15%, the next day it seems like the battery doesn't last as long. I have found that if you are having these battery issues with the G2, all I do is:
    - Charge phone to 100% capacity
    -(With phone still plugged in @ 100% capacity), hold the power button on the back, and do a soft restart. Once the phone is back up and running again, you're good to go!
    I think what this does is re-calibrate the battery, so it knows exactly where 0% charge is, so you get more accurate readings. Found this out after trying multiple things, so I figured I'd share to try and help out other people
  2. #2
    Default Re: LG G2 battery issue FIX
    I will give it a try!
  3. #3
    Jastow's Avatar
    Posts
    Global Posts
    146 Global Posts
    I've had good results with this, thanks!
    posted from LG G2
  4. #4
    Will try! Thanks
  1. Since Yesterday Battery discharging Fast
    By Jillxz in forum Verizon LG G2
    Last Post: 04-21-2014, 11:48 PM
  2. HTC One (M8): Gestures and battery life
    By johnnyshinta in forum HTC One M8
    Last Post: 04-09-2014, 12:11 PM
  3. microphone issue
    By Sarah1564 in forum Google Nexus 5
    Last Post: 04-09-2014, 10:11 AM
  4. DNS issues??
    By snipsey2 in forum AT&T LG G2
    Last Post: 04-08-2014, 09:20 PM
  5. RAVpower 2250mah battery review
    By AxlMyk in forum Samsung Galaxy S3 Accessories
    Last Post: 04-08-2014, 05:29 PM
