Results 1 to 3 of 3
    Default Why does "Phone" take up so much battery when idle?
    I don't make many phone calls, but it seems like when I do the phone continues to use battery after the phone call ends, and I can't force close it from the battery monitor. Any ideas how to fix this?
  2. #2
    Default Re: Why does "Phone" take up so much battery when idle?
    Quote Originally Posted by pantlesspenguin View Post
    Does your phone feel hot after making a call?
    Also, check and make a note of your phone's data usage for the day (mobile and wifi) just before making a call... and then check your data usage again about 5-10 mins after the call. If you find certain apps (the play store, for example) have all of a sudden started to use a lot of data then you have the same problem that I had.
    The only fix I could find was a factory reset.
    Quote Originally Posted by Sincs View Post
    Hmm, I don't think it gets too hot, but I have it in a case so it might and I'm just not noticing. And yes, I also see Foursquare popping up even if I haven't used it at all. A factory reset might be in order this weekend .
  1. Galaxy S5: No access to keypad during phone calls!
    By Marc Wilson 57 in forum Samsung Galaxy S5
    Last Post: Yesterday, 10:31 PM
  2. HTC M8 battery
    By thepurpleturtle in forum HTC One M8
    Last Post: 02-22-2015, 12:01 PM
  3. QUESTION: Why is my battery doing this?
    By DudeThatsErin in forum T-Mobile Samsung Galaxy S4
    Last Post: 05-06-2014, 06:19 PM
  4. Screen turns off when tilted
    By Jon Lithgow in forum Samsung Galaxy S5
    Last Post: 05-02-2014, 10:23 AM
  5. Backing up data on 2nd SD card partition.
    By tinman9898 in forum Android 2.3 Gingerbread
    Last Post: 05-02-2014, 06:25 AM
