1. Gavvykinz's Avatar
    Hey guys i got lg g2. And when i fully charge it the voltage is 4.4?? That cant be right. It says lithium battries shouldnt get higher than 4.2 so whats going on here? Thanks. Please if you have this phone try check too please
    05-23-2014 02:17 AM
  2. OhAlfie's Avatar
    Is the battery working as it should? Are you getting great battery life like most of us? If so, what does it really matter what voltage it is?
    05-23-2014 09:03 AM
  3. acejavelin's Avatar
    Over 4.2 is common, and not just on the G2... My Nexus 4 reports 4.35v-4.40v when fully charged.
    Sent from my Nexus 4 using Tapatalk
    05-23-2014 10:06 AM
  4. Gavvykinz's Avatar
    Great battery life. Was just worried because it shows me 4.4 volts when at 100%
    05-24-2014 09:45 AM
  1. nexus 5 battery case?
    By ianhanson85 in forum Nexus 5 Accessories
    Last Post: 06-07-2014, 11:36 PM
  2. How long does it take to charge an Android tablet?
    By Jellal in forum General Help and How To
    Last Post: 05-23-2014, 11:57 PM
  3. overheating and battery drain solution here
    By JLTEEXO in forum Samsung Galaxy S4
    Last Post: 05-23-2014, 10:30 AM
  4. Awake Entire Day, Still Great Battery Life
    By trojanman in forum HTC One M8
    Last Post: 05-23-2014, 12:47 AM
  5. Problem with WiFi and 3rd party apps
    By debslosingit in forum Android 4.4 KitKat
    Last Post: 05-22-2014, 11:50 PM
