normal battery consumption for LG keyboard?
JozayG2
Active member
Feb 26, 2014
26
Screenshot_2014-07-29-15-38-21.jpgI looked on the battery doctor application and it says my keyboard is 44% battery consumption bearing in mind that I do not use predictive texts or autocorrect is this normal?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,725
113
Your battery level shows that you're pretty close to 100%, so checking battery stats that soon after a full charge isn't entirely useful. If you were just doing a lot of intensive typing on WhatsApp or BBM, then that short period of battery usage may have been due largely to the keyboard, especially if you have vibrate on. Wait until the battery is down to 20-30%, then see what the keyboard usage is.
Akshay
