1. Essam H's Avatar
    i have lg g2 D802
    when i use my 3G Data i can use the internet for 5 hours from 100% to 10%
    screen brightness is low
    location Off
    sync off
    is it normal for G2 ?
    please it's important for me i need clear answer
    thanks
    08-17-2014 07:48 AM
  2. Reicta's Avatar
    Do you mean five hours screen on total? Or five hours straight browsing the web? Either way I'd say it's pretty typical.
    08-17-2014 07:55 AM
  3. Essam H's Avatar
    5 hours using the internet
    facebook
    whatsapp
    and sometimes browsing the web
    08-17-2014 09:25 AM
  4. Mikey47's Avatar
    I think what Reicta was getting at is if your phone is in constant use for 5 hours, or if total use is 2 hours and 3 hours sitting idle.
    It would be help to post a screen shot of battery usage too.
    08-17-2014 12:04 PM
  5. Essam H's Avatar
    08-17-2014 05:09 PM
  6. Arielp228's Avatar
    5 hours is pretty normal ..
    I have kind of the same results
    08-18-2014 03:19 PM
  1. Phone stuck in twrp
    Last Post: 08-18-2014, 07:01 AM
  2. need assistance with 900F
    By osrs360 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-17-2014, 08:52 AM
  3. Replies: 2
    Last Post: 08-17-2014, 06:42 AM
  4. Anyone? Please Help!
    By Kenn Mondina in forum Ask a Question
    Last Post: 08-17-2014, 06:15 AM
  5. S4 ActiveSync with multiple calenders.
    By johndoe7999 in forum Ask a Question
    Last Post: 08-17-2014, 03:33 AM
