I used to get a good 2 days of battery use on my G2 but it is now becoming a dog. Until less than a week ago I used to get a battery drain of around 2-2.5% per hour with moderate use now I am experiencing 8-10% per hour. I have not changed anything, not installed any new apps and I still use it in a high reception area. I have noted that the Android System, which used to eat 10-15% battery is now using 50-60%, but I repeat I have not done anything at all. Is anyone having similar issues? Anyone knows how to fix the problem?
Thanks,
C
Thanks,
C
