1. Brian Stewart1's Avatar
    Anyone using wireless charging with the G3?
    i just cant seem to get it to work
    i've tried a variety of chargers but everytime the phone complains that its not in the correct position ... (no matter where i move it to?)
    07-17-2014 07:22 AM
  2. scottysize's Avatar
    Qi Charging doesn't work in the States, if that's where you are. (No idea from your post.) The back cover plate isn't the correct one on the phones in the States. If you take your battery cover off and look at the inside of it, you'll probably see 2 gold prongs. There should be 4. If you're on AT&T, I've heard they did something to completely disable the Qi charging, even if you have the correct back.
    07-17-2014 07:52 AM
  1. LG G3, can we get Polaris Office with it?
    Last Post: 02-27-2015, 09:10 PM
  2. hotpad q85 4gb wireless problem
    Last Post: 07-20-2014, 06:44 PM
  3. lg optimus g pro e988 getting silent
    By Unregistered in forum Ask a Question
    Last Post: 07-17-2014, 12:35 PM
  4. Why use a AndroidWearOS
    Last Post: 07-17-2014, 03:59 AM
