1. eunesh's Avatar
    I suppose it's just a minor issue, but it is a bit hard to put the charger cord into the charging port. I have to fiddle around trying to put it in for a few seconds. I just expect it to go into the port swiftly and in one try.... Is anyone having this problem?
    I'm coming from a Galaxy S3. And now I have the G3 on AT&T. Its probably just an isolated issue.
    FYI- using stock AT&T charger.
    07-17-2014 09:54 PM
  2. Lorak's Avatar
    I think everyone has reported this. It's goes in at a little bit of an angle. Mine has gotten easier over the week though.
    07-17-2014 09:57 PM
  3. GrooveRite's Avatar
    I've had to fiddle with mine as well but it has been getting easier the more I connect to my device. Just be easy with it. You don't want to mess up and/or damage the port.
    07-17-2014 10:03 PM
  4. Blazer's Avatar
    sames here... seems to be improving... gonna give it a couple of weeks to see if it smooths out.
    07-17-2014 10:12 PM
  5. eunesh's Avatar
    Exactly. Just trying to avoid damaging the port.
    Posted via Android Central App on AT&T LG G3
    07-17-2014 10:18 PM
  1. disable charge complete notification sound
    By preternatural in forum LG G3
    Last Post: 08-23-2014, 11:16 AM
  2. LG G3 Zagg Glass Screen Protector
    By AKFL3TCH3R in forum LG G3
    Last Post: 08-03-2014, 06:14 AM
  3. Mobile Data problems???
    Last Post: 07-17-2014, 10:42 PM
  4. Replies: 0
    Last Post: 07-17-2014, 09:04 PM
  5. Problems with 2013 outlook email sync with Galaxy S5
    Last Post: 07-17-2014, 04:40 PM
