1. zebra23's Avatar
    Just picked up G3, Verizon. After several hours of use, noticed sound became very, very low and when I held the phone to my ear , the lower speaker was not not working. Even at full blastIi could barely hear it. Took 2 factory resets to fix issue. Also, noticed the Knock code screen unlock malfunctions. For instance, I set up four knocks upper right hand corner. I can unlock the phone by tapping any corner 4 times. Even after the resets, the Knock code still doesn't work. I return the phone and get another one. No sound issues, same Knock code issues and also the stock pattern lock will malfunction. Sometimes I don't have to draw the pattern to unlock my phone. It just has me swipe it. Hopefully LG will put an update out. Still have 11 days to try this phone, but it's not looking promising if the security bugs can't get fixed.
    07-20-2014 12:15 PM
  2. godsidekurt's Avatar
    I have had issues with knock code staying as my lockscreen...randomly goes back to swipe after a period. Not a huge deal for me as I think it will be fixed in upcoming software update.
    07-20-2014 02:44 PM
  3. arisenfury's Avatar
    Check the lock timeout, I have mine set to 10 minutes.
    07-20-2014 05:28 PM
  1. HTC One M8 Battery issue!!!
    By muzia1 in forum HTC One M8
    Last Post: 07-25-2014, 12:02 AM
  2. Issues with running the device.
    By gavsterr in forum Motorola Droid Ultra
    Last Post: 07-20-2014, 08:32 PM
  3. Camera Shutter Sound off?
    By AlwaysSmile in forum LG G3
    Last Post: 07-20-2014, 05:26 PM
  4. Replies: 2
    Last Post: 07-20-2014, 09:10 AM
  5. KI KAT issues on Verizon G2 and S4? - HELP!
    By indymo33 in forum Verizon Samsung Galaxy S4
    Last Post: 07-19-2014, 09:02 PM
