01-19-2016 08:14 AM
118 ... 345
tools
  1. MC_A_DOT's Avatar
    MY SOLUTION
    I have experienced these HORRIBLE issues myself. I just found a solution that is working great for me.
    I purchased a Headset Splitter Adapter (so the microphone and headset get split) and use the headset split as the feed going to my car. Now the LG G3 works flawlessly for me.
    Hummm forum won't let me post a link so...
    cirago dot com slash axc2earmic dot php
    I doubt that people want to walk around and have to use a headset splitter just to listen to some music all make calls on the go.
    12-04-2014 03:08 AM
  2. rockijames's Avatar
    Is this the same problem people are having with Bluetooth as well? I just got my phone on Monday and have to have the volume up full blast in my van to hear people on Bluetooth. I have made sure sound reduction is on but I'm not sure what else to do.
    12-04-2014 07:37 AM
  3. Douglas Ibrahim's Avatar
    According to LG using an aux cord with a volume control will resolve the issue for now
    12-08-2014 12:46 PM
  4. Douglas Ibrahim's Avatar
    withdrawn
    12-08-2014 12:59 PM
  5. Douglas Ibrahim's Avatar
    withdrawn
    12-08-2014 01:20 PM
  6. Juan Carlos Melgarejo's Avatar
    It might work, I have exactly the same problem with a Huawei G730, it works like a charm with wired headphones, and with cassette adapter on my car (yes, is a 23 year old car, only has cassette, no CD, no Aux ), it never worked with my house Stereo....... until today........ I have a "y" cable (2 female, 1 male 3.5 milimeter), male goes to the phone, female 1 goes to Aux input of the house Stereo and... female 2 goes to ........(here is the trick)..... Another cassette adapter, no pop sound, no hiisss noise or static, it works flawlessly....., it does not work that good with headphones on female 2 (sound level goes down by half), i will do and experiment cutting the headphones, peeling cables and crossing them to do a sort circuit and se if that keeps the audio on from the phone
    12-08-2014 05:07 PM
  7. meyerweb#CB's Avatar
    The latest update from Sprint, and I believe other carriers, is supposed to have improvements for the aux cord issues.
    12-08-2014 05:24 PM
  8. Wildo6882's Avatar
    Yeah, I'm still looking into this phone, but this is seriously a deal breaker. Has this been fixed on AT&T? Or what's the best way to deal with it? My daughter would be angry if she couldn't hear her music in the car.
    12-13-2014 04:02 PM
  9. psp1232171's Avatar
    T-Mobile G3 no issues with cord or Bluetooth. Loving my device so far.
    12-13-2014 09:08 PM
  10. atschai's Avatar
    I'm having this issue only with certain headsets, namely those with low impedance. A workaround I found is to plug in the plug slowly until you hear a hiss in the left channel. The phone then switches into line mode - you can see that in the status bar as it shows a plug instead of a headphone. Sound is then flawless.
    scgf likes this.
    12-14-2014 05:39 AM
  11. jaykim62301's Avatar
    This is a bit similar. Whenever I call on my phone, I try to talk, but an AUX cable symbol pops up and I can't hear anything! I can only hear and talk when I put speaker mode on! Please someone help!!!
    LG G3
    12-24-2014 11:20 PM
  12. Adrian Zr's Avatar
    My lg g3 would pause or skip songs if I moved the phone even a little bit while connected to the car stereo, and also would open the voice mate app frequently. What worked PERFECTLY for me was buying a cable with 3 rings (4 poles as it is known) instead of 2 rings in the connection plug. The same happens when I use headphones with 2 rings vs 3 rings.
    01-20-2015 03:06 PM
  13. shomer80's Avatar
    Did youever figure out a solution to this problem?? I swear of my phone launches Google now while I am on spotify one more time, I am going to throw it out the window. Please Help!
    07-02-2015 08:40 AM
  14. shomer80's Avatar
    Forgot to say in my other post - When I have a regular AUX cable plugged in, if anything touches the jack plugged into the phone, the music either stops or launches Google now. Anyone else getting that? Really infuriating. Feel like that must be a hardware problem rather than software?
    07-02-2015 08:48 AM
  15. irinautkina's Avatar
    Strange. I haven't had any issues with mine.
    Posted via LG G3.
    07-02-2015 11:30 AM
  16. GamingInsider's Avatar
    Are you hitting the home button I. a way that it's launching google now while on spotify?
    07-06-2015 09:25 PM
  17. Joe Redington's Avatar
    I don't know if this is an old thread or not, because I didn't look first, but have you had any luck with your Huawei G730? I bought this phone in Colombia and an using in the US now. Only thing is, no audio out of the aux either. Hoping you found a fix.
    11-24-2015 08:08 PM
  18. jusgot2bkool's Avatar
    That "Honor" deals a "Joke" US only Lol. N E way ! The LG G4 812 has blown my mind so far a lil bit of probs getting my music platform functional and an issue that" me" dummy had making sure the jack was inserted properly as I am rough a protective brute cover over that eloquent leather they have on the phone made the jack port difficult to get insertion correctly. * note anybody using those protective "specialy" the heavy rubberized ones caution b 4 u think its defective, make sure you verify connections without the casing on. Back 2 the phone if you let LG communicate with your phone and verify your not a criminal you will be very blown away with this puppy. After a bad worse terrible no worse than that issues with Bell and Samsucks never 2 b nmy life agains service it is really sincerly nice 2 have Life Good again. Great phone and so far lightening service and supply Rogers still have some distance to cover though.
    01-19-2016 08:14 AM
118 ... 345
  1. Moto E - sound problem, help!
    By ronclone in forum Moto E (2014)
    Last Post: 03-04-2017, 07:11 PM
  2. LG G3 Camera Touch and Shoot disables after resolution change
    Last Post: 09-22-2014, 06:01 PM
  3. S5 or LG g3
    By diegofs89 in forum Samsung Galaxy S5
    Last Post: 07-29-2014, 02:41 PM
  4. LG g3 or samsung galaxy s5
    By diegofs89 in forum LG G3
    Last Post: 07-26-2014, 08:02 PM
  5. T-Mobile LG G3 and International Capabilities
    Last Post: 07-26-2014, 04:41 PM
