1. Thomas Clearo's Avatar
    I have a T-Mobile G3. Great phone, but I'm experiencing a strange issue. When I receive a text message with a photo attached, it won't download the photo unless I turn on mobile data. I have a strong wifi signal, and I don't recall having this issue with the S5 or the HTC One phones. Know I could just leave both wifi and data on, but it just seems like I should be able to download photos via wifi. Am I missing something? Thanks for the help.
    08-11-2014 05:21 PM
  2. VW Maverick's Avatar
    Any other problems seen while on Wi-Fi?
    If yes, try this: http://forums.androidcentral.com/amb...-problems.html
    Mav.
    08-11-2014 05:39 PM
  3. marcus.plans's Avatar
    I haven't had this problem since I had the G2x years ago. It wasn't an issue with the Nexus 4 and 5, but it's once again a problem with a G3. I can't remember if I ever fixed it or if it's fixable, so if someone could share am answer, that would be great.
    Sent from my LG-D851 using Tapatalk
    08-11-2014 05:46 PM
  4. mhunter6378's Avatar
    You need mobile data on for MMS to work, SMS will work without mobile data but MMS needs it.
    B. Diddy likes this.
    08-11-2014 05:54 PM
  5. B. Diddy's Avatar
    Photos over messaging is MMS, which requires mobile data (at least, if you're using the stock Messaging app). I'm not sure if T-Mobile's wi-fi calling features makes it possible to send photos over messaging on wi-fi, but on most other conventional phones, it requires mobile data.
    EDIT: Posted at the same time as mhunter6378!
    mhunter6378 likes this.
    08-11-2014 05:55 PM
  6. Thomas Clearo's Avatar
    Ok. I'll give it a shot. Thanks for the help, everyone.
    08-11-2014 06:22 PM
  7. marcus.plans's Avatar
    Alright, the trick is disabling WiFi calling. Do that and you can send MMS when on WiFi. Just tested myself (turned WiFi calling preference to cellular data preferred).
    08-11-2014 07:48 PM
  1. att 4.4 update downloading
    By iFalcon in forum Moto X (2013)
    Last Post: 08-15-2014, 07:45 AM
  2. Replies: 5
    Last Post: 08-13-2014, 07:00 AM
  3. Any help with nexus 5 draining battery
    By ashleigh089 in forum Ask a Question
    Last Post: 08-11-2014, 06:01 PM
  4. Samsung Galaxy 4 scree won't light up but ph works!
    Last Post: 08-11-2014, 05:35 PM
  5. Replies: 1
    Last Post: 08-11-2014, 04:50 PM
