04-03-2016 01:15 PM
51 123
tools
  1. Adrian Bankhead's Avatar
    So I'm a recent convert to android after five years of iphone, which I had gotten bored with. And I gotta say, I *love* the g3, which is pretty much perfect in all respects except for the lg's creepy and intrusive voice mate app. Omg I hate this app! It intrudes randomly on my music at least 30+ times a day asking if I need anything, even though I hadn't said anything. And so I try to turn it off but I can't - there's no off switch! And so ok voice mate screw you - ill just disable the app. But that doesn't work because Im interrupted *twice as much* with notifications to reinstall. And when I ignore those notifications, super-creepy voice mate re-installs itself anyway! And so oh now I'm pissed ("siri didnt do this!!!"), so I turn off auto-update, which is great because voice mate is now gone for good I hope, except that the stupid annoying notifications nagging me to reinstall voice mate still interrupt me 8000+ times a day. Seriously, im obsessed, and im *totally* ready to root my phone to get rid of this goddamned app (bring. it. on. - i should have switched to android *years ago*). And so specifically I want to know if anyone has successfully completely removed voicemate from their phones, or perhaps without rooting, to turn the update nagging off? Because - understand, voice mate must be defeated. I have to kill it!
    Andrei Balashov likes this.
    08-15-2014 01:15 AM
  2. areyes163's Avatar
    Sorry. I have not even used the app nor have I heard from it.
    08-15-2014 01:19 AM
  3. Adrian Bankhead's Avatar
    Omg how can I be just like you???
    08-15-2014 01:23 AM
  4. makie's Avatar
    Lol neither have i. But since I live in the Netherlands I wouldn't use it anyway, cause it's probably English only.
    08-15-2014 01:48 AM
  5. stevovr's Avatar
    swipe from the bottom to open the app and go into settings. small gear top right corner of screen.
    08-15-2014 10:31 AM
  6. Adrian Bankhead's Avatar
    Ok so I reinstalled voice mate just to check that out and no, that doesn't turn voice mate off (i've been to that screen like a million times already). And thats because *there is no way* to turn voice mate off, short of rooting your phone.
    08-15-2014 07:34 PM
  7. idon12no's Avatar
    Is it because you have headphones plugged in? I don't think I've ever had this app bother me after tri week's with the phone.
    08-15-2014 08:06 PM
  8. Ardi Noer's Avatar
    good luck for your mate, hope you resolve it
    Adrian Bankhead likes this.
    08-16-2014 05:20 AM
  9. Adrian Bankhead's Avatar
    So I rooted my phone and rather than blowing up voice mate with dynamite as originally planned, I froze the app using Transmission Pro, and that seems to have stopped not only the app itself but the endless (and infinitely annoying) install nags as well. Im like, "ahh, blissful silence..." Its like the baby stopped crying. I'm beginning to cry with quiet joy and relief that my phone might finally be free of the Monster. Fingers crossed... Please say a prayer for me.
    Posted via the Android Central
    kj11 likes this.
    08-19-2014 01:22 PM
  10. Duncan1982's Avatar
    Dear lord who resides in heaven, may the voice inside his phone be dead and gone.
    Amen lol
    Ahhh was a joke OK :-P
    PaulyZinATL and nodnarb1974 like this.
    08-19-2014 02:03 PM
  11. Gator352's Avatar
    All you had to do is this:
    Settings > apps > scroll to all > find voice command > clear cache and data > tap disable > find Voice mate > clear cache and data > tap disable
    This disables both apps to never be heard from again.
    08-19-2014 06:06 PM
  12. Adrian Bankhead's Avatar
    No gator - disabling voice mate doesn't work! What happens when you do that is that it sends you these annoying nag notifications that you should reinstall voice mate. These messages stop whatever you are doing and are extremely aggravating. If you ignore them lg reinstalls voice mate automatically after 24 hours and so I did everything you said every morning until I was ready to set my phone on 🔥 And so you say the solution to automatic re-installation is to turn off auto-update in the google store. And yes that prevents voice mate from reinstalling, but it doesn't stop the constant notifications! That's where I started my first post. The only way to get rid of the notifications is to root your phone and freeze or nuke voice mate completely. Its a unique app. Try to get rid of it and let me know if it stays gone.
    08-19-2014 09:22 PM
  13. Adrian Bankhead's Avatar
    Oh and thanks Duncan 1982! I dont know if it was your prayer or my Sub-Zero fatality moves* but im happy to say that my phone has been perfectly silent all day and im so chill right now omg this is heaven lol.
    * e.g. - http:/ /youtu.be/lQSMWcXoVA0
    08-19-2014 09:37 PM
  14. Sailindawg's Avatar
    @Adrian
    What carrier are you using?
    08-20-2014 06:55 AM
  15. Adrian Bankhead's Avatar
    Sail - im on tmobile
    08-20-2014 04:02 PM
  16. Phillip Williams Jr's Avatar
    I am I'm the middle of this and it happens when I plug in certain earphones.
    08-26-2014 08:28 PM
  17. Andrei Balashov's Avatar
    So I'm a recent convert to android after five years of iphone, which I had gotten bored with. And I gotta say, I *love* the g3, which is pretty much perfect in all respects except for the lg's creepy and intrusive voice mate app. Omg I hate this app! ... I have to kill it!
    How do you undelete it? I hate it even harder, man
    09-10-2014 11:01 AM
  18. Fredrik Burmester's Avatar
    Easiest way (root) is to go in to your file browser of choice and find the file libQvoiceActivation.so and remove it. Done. Don't even need to reboot the device. Be sure to make a copy of the file if you want Voice Mate back.
    11-07-2014 04:41 AM
  19. kj11's Avatar
    I've never heard anything from voice mate myself... Sounds pretty annoying though.
    11-07-2014 07:54 AM
  20. HULKchampion's Avatar
    Ugh, I have the same problem. Haven't been able to find a way to stop this. I didn't root my phone and hoping there'll be way to stop it
    11-07-2014 05:45 PM
  21. zhris's Avatar
    Totally not sarcastic, but... what's a Voice Mate? I've had my G3 for a couple months and this is the first I've heard of it.
    11-07-2014 05:51 PM
  22. KeepItReal's Avatar
    I avoid VoiceMate like the plaque, as its horrible. However, I never activate it, and it doesn't intrude. It only intrudes when I use my cars Bluetooth....when I use voice commands, it never understands a dang thing I say. I have tried to make Google Now the default (I want to talk saying Ok Google Now from the screen asleep like the Motorola's....) but alas, it was too clughy. There should be a setting to choose. Or LG....get your game on and improve your voice app!
    11-07-2014 08:09 PM
  23. Stephany Scott's Avatar
    OMG you have no idea how much I love you!!!! I had same issue a person who started thread. Voice memo pops up inconveniently. While I'm watching movies or just on my phone. For so annoying I was ready to break my phone. Until you came along and saved me from insanity. Thank you so much.
    01-10-2015 02:37 AM
  24. chimpboy74's Avatar
    Never had voice mate do anything on my phone. I was vaguely aware it existed but I'm not sure if know how to find it!!
    01-10-2015 09:32 AM
  25. jshadow's Avatar
    Root your phone and freeze the apps called Voice Mate, Voice Mate Engine and Voice Mate Speech Pack with Titanium Backup.
    01-10-2015 10:41 AM
51 123
  1. LG G2 Colors turned funky
    Last Post: 01-28-2017, 08:21 AM
  2. LG optimus L90 and snap chat help!
    Last Post: 10-12-2015, 06:56 AM
  3. I cant start my lg e460
    By Vicent5 in forum Ask a Question
    Last Post: 10-06-2014, 05:55 AM
  4. Help! How do I transfer my messages from iPhone to LG G3 ?
    Last Post: 08-14-2014, 08:37 PM
  5. Replies: 2
    Last Post: 08-14-2014, 08:19 PM
