1. matt3166's Avatar
    I just want to get it straight. There is no way, 100% to get QI charging on G3 with AT&T. Only PowerMate? I found some unlocked G3 back plates on eBay with he correct pins but is QI completely disabled?
    08-17-2014 09:57 AM
  2. mhunter6378's Avatar
    AT&T borked the Qi capabilities in lieu of PMA which they are pushing. If you really need Qi one option is a charging receiver that fits inside the back cover and has a thin cable that plugs into the micro USB port. It works but you lose the micro USB port while it is installed. So connecting to a standard charger or hooking up to a computer is not possible without removing the Qi receiver first. Here's a link
    Universal Qi Wireless Charging Pad Charger Receiver Micro USB for Mobile Phone | eBay
    08-17-2014 10:34 AM
  3. makie's Avatar
    Lool, even tho you get phones/contracts cheap in the US, you really get weird carriers.
    Why in f.. Sake would they disable qi charging??
    Posted with the speed of my G3
    08-17-2014 04:42 PM
  1. Moto E Not charging : Lightning bolt visible though
    Last Post: 03-26-2015, 03:20 AM
  2. G3 vs. iPhone 6 vs. Lumia 1520
    By BobLobIaw in forum LG G3
    Last Post: 08-21-2014, 11:56 AM
  3. Replies: 14
    Last Post: 08-19-2014, 03:02 PM
  4. Samsung S4 Mini I9192 take long time to charge.
    By partheep in forum Samsung Galaxy S4 Mini
    Last Post: 08-17-2014, 08:24 AM
  5. LG G3 smart phone smokes Amazon Fire
    By Herennow in forum LG G3
    Last Post: 08-17-2014, 08:05 AM
