Results 1 to 16 of 16
    The Husain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Awful Battery
    Hello all.. I'm getting AWFUL battery life. It's been 15 days I got my phone. I spent a small fortune to get this phone, and now I can't even get through Half of the day..watching so many people posting awesome results about their battery life, I'm unable to understand why only my phone is lacking so much. Please suggest me something. I'm using stock unrooted phone and don't want to root it.
    Attached Thumbnails Attached Thumbnails Awful Battery-quickmemo-_2014-08-15-16-48-02.jpg   Awful Battery-quickmemo-_2014-08-15-16-48-14.jpg
  2. #2
    xocomaox's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Awful Battery
    Seems pretty bad looking at the numbers.
  3. #3
    Duncan1982's Avatar
    Banned
    Posts
    Global Posts
    1,920 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have noticed that is with battery saving turned on.
    There are updates rolling out here in Scotland, not sure about America that in my opinion are helping with battery life :-)
    It could be a rogue app that is causing it.
    Try going into your apps and see what one is possibly causing an issue.
  4. #4
    o4liberty's Avatar
    Posts
    Global Posts
    4,311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Some apps will drain the battery very quickly need to see which ones. I get 8 hours with heavy use.
    The Husain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any suggestion how to identify such apps?
  6. #6
    ShinyTop's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Two ways to identify rogue apps. Uninstall apps until the battery issue disappears. Last app uninstalled was the culprit. Other way is to wipe the phone and start over. Only install one app at a time until your battery life goes away.
    Before I would do that I would turn off most notifications and change sync where you can to off or extend the time. My FB and pop email I have to no auto sync. My Gmail only sync every 15 minutes.
    My battery goes down less than 5% while I am at work unless I use it which is seldom. If I forget to charge it overnight it only goes down about 4-5 %. Really sounds like you have an app that is pulling a lot of juice.
    Oh, and I leave BT and WiFi on all the time. But if you are often out of Wifi I would turn it off. Also if you are in a weak signal area you phone will use a lot of battery trying to find a signal.
  7. #7
    o4liberty's Avatar
    Posts
    Global Posts
    4,311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by The Husain View Post
    Go into settings and battery look at usage.
  8. #8
    Freecableguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm also getting similar BL times, around 3 hours on D855 32GB 10b. Should I update to 10e? I read somewhere at XDA that 10e had worse battery life.
  9. #9
    belodion's Avatar
    Posts
    Global Posts
    19,896 Global Posts
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Freecableguy View Post
    I have good battery life and it made no difference (so far as I'm aware) when I received the 10e update, nor later when I received 10g.
  10. #10
    o4liberty's Avatar
    Posts
    Global Posts
    4,311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Battery life all depends on the user and how the device is set up. One of the biggest things that drain a battery is lack of cellular signal, when a device is constantly looking for a signal your battery suffers.
  11. #11
    WordPainter's Avatar
    Posts
    Global Posts
    225 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7(Nook)
    I'm getting 14-16 hrs easy with moderate/heavy use. Don't bash the phone. You are either running an app that sucks battery or forces long wakelocks, or you are in an area with poor signal. When a phone struggles to get and keep a signal (esp 3G) it will kill battery life in no time-in fact I see you are in roaming mode in your screenshots, so that would explain a lot. Did you check coverage maps in your area before choosing a carrier?
  12. #12
    drewsg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just a heads up, the brightness on this phone drains the battery like crazy. The battery I experience between when the brightness is turned up and when it's off is drastic. I know this should be common sense, but I don't think people realize just how much the brightness is a drain on this phone.
  13. #13
    alcantarvf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My first G3 gave me awful battery life... I replaced it on my 7th day at TMobile store... New one is so much better... Almost 5 hours on screen time. Battery completely empty between 12-15 hours of use. To me that is good considering that I am a heavy heavy user. My phone is my companion.... Old one would drain in 6 hours of similar use... SOT of only 2.5 to 3 hours
  14. #14
    Duncan1982's Avatar
    Banned
    Posts
    Global Posts
    1,920 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Time for a charge lol 6hrs of screen on time :-)
    Attached Thumbnails Attached Thumbnails Awful Battery-1408312764103.jpg   Awful Battery-1408312781309.jpg
  15. #15
    HULKchampion's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know for sure. Facebook app is a battery hog. Before I added the application, over night discharge is at most 1%. With Facebook app, it's about 3-4%. I have all the sync items turned off too. You better check your phones application you've installed. My phones battery is awesome! I get through the whole day with heavy usage, screen on time about 4.5-5 hours.
  16. #16
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just updated to 10e (yea I know I'm late) and I cant check screen on-time @ battery section anymore.. no sign of screen % of battery used
  1. Zerolemon 1000mAh Battery!
    By AlfBriggs in forum Samsung Galaxy Note 3
    Last Post: 09-07-2014, 04:13 PM
  2. Terrible battery usage
    By Parham Goudarzi in forum Samsung Galaxy S5
    Last Post: 08-27-2014, 09:44 PM
  3. Samsung New battery doesn't work.
    Last Post: 08-20-2014, 04:10 AM
  4. about battery
    Last Post: 08-17-2014, 02:38 AM
  5. A Gamers Average battery life
    By Dan Derp in forum Ask a Question
    Last Post: 08-17-2014, 01:05 AM
