1. xmutan's Avatar
    hi, i'm from indonesia
    just bought lg g3 a month ago, suddenly front facing camera not working, try to clear the cache and still hangs "Unfortunately, Camera has stopped"
    no problem with the rear camera, only happens when i turn to front camera, and it hangs
    software version: v10g-ESA-XX
    thanks for helping
    08-22-2014 08:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You tried to clear the app cache of the Camera app? Or tried to clear the system cache partition? From what I can tell on the web, the latter isn't possible on an unrooted G3.
    Try booting into Safe Mode, which temporarily disables all 3rd party apps. If the problem resolves, then something you installed is interfering with the front camera. If the problem continues, then there is probably a hardware or firmware problem, and you should contact the store you got the phone from or LG for warranty replacement or repair. Safe mode: LG G3 | T-Mobile Support
    GrooveRite likes this.
    08-22-2014 11:18 AM
  3. xmutan's Avatar
    yes i've tried safe mode still front facing not working, but rear camera works, before just fine, suddenly goes wrong, i didn't install new apps
    08-23-2014 12:54 AM
  4. B. Diddy's Avatar
    If it's not working in Safe Mode, there's a fundamental problem with the hardware or firmware. Bring it back to the store where you bought it, or contact LG for repair or replacement.
    08-23-2014 01:01 AM
  1. Wifi can not be enabled while in airplane mode at kitkat
    Last Post: 01-02-2015, 04:12 AM
  2. XNPH33R has been released for OnePlus One
    By megatomic in forum OnePlus One
    Last Post: 08-26-2014, 12:27 PM
  3. us cellular galaxy s5 wifi help
    Last Post: 08-22-2014, 08:50 AM
  4. Replies: 0
    Last Post: 08-22-2014, 08:05 AM
