Results 1 to 13 of 13
Like Tree4Likes
  • 1 Post By mhunter6378
  • 1 Post By pmcnei11
  • 1 Post By Wikh
    avolkering's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default HELP!!!! problems with multitasking
    i just purchased an LG G3 a few days ago and have loved the phone so far except for one thing that keeps bugging me. The phone doesnt seem to be able to multitask. whenever i try and switch between an open app and an app I have just had open, the app im switching to seems to always reload itself. so when multitasking between things such as candy crush, FB, youtube, snapchat, etc the app will open and reload itself.
    Is anyone else experiencing similar issues?
  2. #2
    VDub2174's Avatar
    Posts
    Global Posts
    5,775 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: HELP!!!! problems with multitasking
    I haven't had any issues with this on my G3. Have you tried using the multi-window feature instead?
  3. #3
    sc_al's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry how do you get Facebook to be one of the apps you can multitask on, I can only use a few apps Like calculator and gallery but none of the one's I want to like tapatalk or whatsapp or Facebook?
    Sent from my LG-D855 using Tapatalk
  4. #4
    pmcnei11's Avatar
    Posts
    Global Posts
    162 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by avolkering View Post
    Do you have a 2GB Ram version? The same happened to another poster on here.If so you're running out of Ram.
  5. #5
    mhunter6378's Avatar
    Posts
    Global Posts
    1,262 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pmcnei11 View Post
    Yes there is another thread, I think it was Wikh that had the issue with a 2gb version. But in the end IIRC he had a bunch of apps moved to SD and that was what was causing his issues. I'll look for the thread and link it.
    Wikh likes this.
    avolkering's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yeah i have the 16GB, 2 GB RAM version. How can i limit the amount of RAM that the LG software is taking up?
  7. #7
    pmcnei11's Avatar
    Posts
    Global Posts
    162 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Debloat LGs software and use Nova Launcher. The other poster in here ended up selling the 2Gb version and buying the 3GB. The QHD display also uses double the Ram(as video Ram) an HD display uses 300mb Vs 600mb.
    Wikh likes this.
  8. #8
    Posts
    Global Posts
    1,262 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wikh likes this.
  9. #9
    pmcnei11's Avatar
    Posts
    Global Posts
    162 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ahhhhh, I thought he got the 3gb in the end.
    mhunter6378 likes this.
  10. #10
    Wikh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did.
    pmcnei11 likes this.
  11. #11
    Wikh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There isn't a real solution for that - that's all you have with the 2gb version.
    By moving apps to the phone it helped a little bit but still bugged me out! Ask anything - I'm subscribed to this topic and I can try to help.
  12. #12
    idon12no's Avatar
    Posts
    Global Posts
    788 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I have a video running on the browser and I minimize the window, the video will stop. What's up with that?
    T-Mobile G3
  13. #13
    Wikh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think the page will reload. Same thing happened to youtube for me.
    Or to the AC forum app. Every single time it restarted.
  1. An android developer's first contact with iOS
    By alinescoo in forum General News & Discussion
    Last Post: 09-24-2014, 09:39 AM
  2. New LG G3 with gorilla glass, scratched! help
    Last Post: 09-05-2014, 10:09 PM
  3. Fixes to common Android L problems?
    By DrDoctor in forum Google Nexus 5
    Last Post: 09-02-2014, 01:31 PM
  4. LG G3 does not multitask.
    Last Post: 08-29-2014, 04:58 PM
  5. Overheating issues with S5 since last software update
    By mallorey in forum Samsung Galaxy S5
    Last Post: 08-29-2014, 10:38 AM
