Results 1 to 12 of 12
    Murph5150's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Euroskank CM10
    Default We need an extended life battery.
    I'm not in a horrible reception and I spent 10 minutes on it and battery was at 24%. I've covered the basics and all seems fine.
    Attached Thumbnails Attached Thumbnails We need an extended life battery.-4955.jpg
  2. #2
    markwest1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: We need an extended life battery.
    I charge my G3 once ever 2-3 days. Extremely happy with the battery life. On my previous device (HTC One M7) I was lucky to get through one day, especially with WIFI turned on.
    Murph5150's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Euroskank CM10
    I'm waiting for the extended battery for my phone.
  4. #4
    bongaroo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What are you doing with your phone? Ive been using fairly heavily today and I am at 42%.
    Posted via my LG G3
    Murph5150's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Euroskank CM10
    Quote Originally Posted by bongaroo View Post
    Posted via my LG G3
    Lol it sits in my pocket. All extras are off and I checked to see if an app was responsible for the drain, but I didn't find one.
  6. #6
    daddyd302's Avatar
    Posts
    Global Posts
    246 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Murph5150 View Post
    https://www.facebook.com/zerolemon/p...98171400275804
  7. #7
    belodion's Avatar
    Posts
    Global Posts
    19,839 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I seem to remember posting a link similar to daddyd302's about a ZeroLemon battery, and I thought that was in one of your earlier threads, could be mistaken....but is this the one you're waiting for?
    However you shouldn't have to depend on an extended capacity battery to be able to use your phone. If as you say you've done all the normal checks and battery life is still bad, a finger is pointed, if not at, then at least in the direction of, the battery. Would not a new normal battery be an option?
  8. #8
    LGElectronics's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, I am sorry to hear you are having battery issues with your LG handset. Can you pls tell me what carrier, model and software version you are currently using?^MA
  9. #9
    tech_head's Avatar
    Posts
    Global Posts
    1,337 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Something is wrong.
    You need to see what is draining your battery.
    I can go all day away from a charger and never hit 24%.
    What widgets do you have updating?
    Try using the Qualcom Battery Guru.
    It will take a week to see the apps you run, then you can decide how to let them update.
  10. #10
    urrl's Avatar
    Posts
    Global Posts
    102 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found swapping out my SD card improved the battery performance.
    http://forums.androidcentral.com/lg-...ml#post3859307
    However using the phone constantly with the screen on 50% or more will still drain the battery more than I would like. I hope they come up with a thicker battery for this phone with the appropriate back cover like they did my old Galaxy S3 which gave it twice the battery life. Then I would not look twice at another type phone be it GN4 or iPhone 6. I already have two extra batteries but a single more powerful battery is what I now want, I don't care about the phone being a bit thicker.
  11. #11
    Lapse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I find that gps combined with a bright screen uses up a lot of battery. I'm pleased with my extra battery, and now just pop it in if I'm getting low at the end of the day. I'd rather do that than weight down the phone with a heavier battery that wouldn't work with my case.
  12. #12
    urrl's Avatar
    Posts
    Global Posts
    102 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know why I should complain. I turned on my G3 about 9AM and here it is 11PM with 70% left. Screen was at 30%, I downloaded a full movie, made a few calls. I'm not a phone junkie and that's a good thing with this phone. Guess I should be satisfied. What you say about the screen and GPS is what the GSAM battery monitor is telling me about the most battery drain so I should mention I also turned off my GPS for most of the day. I also use the Battery Doctor app. Wow...70% though, really.
    I still want a bigger battery though. I do not want to make any sacrifices for longer life and I want more than a days worth of heavy use, like I had with my GS3 with the bigger battery.
  1. How to do a hard reset on an LG G2
    By Oluwadare Oyadiji in forum LG G2
    Last Post: 02-08-2015, 03:19 PM
  2. Can I sim-unlock an AT&T-locked Note 8?
    By teffects in forum Samsung Galaxy Note 8.0
    Last Post: 12-15-2014, 05:37 AM
  3. I need some Good free root apps
    By JellyJamStudios in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 09-25-2014, 10:33 PM
  4. Verizon samsung galaxy note 3 battery dying rapidly
    By the1hooper in forum Ask a Question
    Last Post: 09-04-2014, 05:46 AM
