Results 1 to 2 of 2
    Default Charging Test: Same USB cable, different adapter.
    For those of you experiencing battery charging issues, I did an experiment. Using the LG provided USB cable and AC adapter I went from 2% to 100% in 97 minutes. Using my girlfriends Apple provided AC adapter it was 132 minutes. Keep in mind these AC adapters have different amperage values. Whenever I do anything battery related I always stick with factory stuff. Hope this helps!
    Also, for those of you coming over to a G3 from a Galaxy S5, your in for a disappointment because USB 3.0 charges quite fast compared to this. I have not done a test but I heard it is around 40min for the 2800mAH battery in there.
  2. #2
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    4,205 Global Posts
    Carrier
    stock
    Default Re: Charging Test: Same USB cable, different adapter.
    Once development takes off. I'm sure there will be a modified kernel to allow fast charging. Thanks for the heads up though. I didn't notice that it took quite some time for me to charge last night
    Sent from my VS985 4G
  1. Replies: 8
    Last Post: 09-04-2014, 08:07 PM
  2. Replies: 2
    Last Post: 09-03-2014, 05:26 AM
  3. Galaxy S4 will not charge or turn on.
    Last Post: 09-02-2014, 04:02 PM
  4. My S3 Won't Charge
    Last Post: 09-02-2014, 10:15 AM
  5. Recording sound at same time as playing sound....
    By Unregistered in forum Ask a Question
    Last Post: 09-02-2014, 09:28 AM
