09-05-2014 03:31 PM
28 12
tools
  1. Stwutter's Avatar
    Hi all.
    It's it normal for the G3 battery to last an unusual length of time to show anything under 100%, but then drain at a more 'normal' rate as soon as it finally dips into the 90's?
    The attached screenshot is from this morning. It took nearly 2 hours to move from full, but then it takes a much steadier downward gradient from then on throughout the rest of the day.
    I have few complaints about the battery life. I'm quite a heavy user, and I'm getting a full days use most days. I've heard that the battery can 'over charge' as such, and maybe this explains it... I'm using mainly the stock charger that came with the phone.
    This isn't a complaint. Just more out of intrigue.
    09-03-2014 01:44 AM
  2. ShAdoWSKy's Avatar
    Was your phone in use during those 2 hours? The G3 has an amazing standby time so I'm not surprised you got those numbers haha.
    09-03-2014 02:51 AM
  3. Stwutter's Avatar
    Yeah it was. A few emails, some internet, sms... The usual first thing in the morning catch up I do everyday. Since my first post, I've used the phone in a similar way, and here's the latest usage. As you can see, it's a lot steadier. Just that almost vertical bit in the first couple of hours.
    09-03-2014 02:59 AM
  4. MC_A_DOT's Avatar
    Hi all.
    This is normal sir and I love it lol
    With heavy use, it takes just over an hour or so before the battery starts to drop on my phone.
    I haven't heard about any over charging issues...link?
    09-03-2014 03:33 AM
  5. Stwutter's Avatar
    Christ - no link, no. Either on here somewhere,or maybe even on Crackberry in days of yore... It may have even just have been someone else with a similar query.
    I don't mind it either, obviously. But it still makes no sense why it would take so long to drop from 100% and then at a more regular rate it does.
    MC_A_DOT likes this.
    09-03-2014 03:47 AM
  6. MC_A_DOT's Avatar
    I know it seems really weird to me too but I can't really complain.
    The battery life on this phone is amazing IMO, by the end of my day it still has at least 60% or so battery.....wizards must have manufactured this phone lol
    I'd love to know how they do it.
    sbeil likes this.
    09-03-2014 04:23 AM
  7. belodion's Avatar
    To be able to use for 2h before it reads lower than 100% is incredible. I've never timed it but can get I'd guess up to half hour's use at 30% brightness, just texting say, before she drops to 99%. Regarding standby I once had a reading at 99% if I recall right of well over a thousand hours....worked out at 42 days I think.
    09-03-2014 05:14 AM
  8. Stwutter's Avatar
    Wow - I realise, of course, that battery consumption is all down to use and applications, but 60% after a full day? I've never got close to that, even on my old Blackberry Z30, which had, IMO, a far superior battery to the G3. I'm currently on 8 hours use - fairly heavy, as I mentioned above - and it's telling me it will die at about 7.30 tonight. This is still 14hrs, which, for a quad 5.5" screen, is still very good. I have a charger for when I'm at my desk, and carry a spare battery. In the month I've had the G3, I've had to use the spare on a few occasions when I've been out from 6am until late evening.
    09-03-2014 06:33 AM
  9. Lapse's Avatar
    Obviously the battery is discharging even when it says 100%, which is why I don't like it that way. The battery is pretty good, but less so using maps on a sunny day, which is why I bought a spare to make it through a long day after being stranded with a dead battery on a trip. Then there is nothing to worry about.
    09-03-2014 06:51 AM
  10. Slashyou's Avatar
    Hi all.
    Seems normal to me my galaxy nexus dies the same thing but games abd stuff does REALLY drian battery life but if brothers you get a power bank to charge it on the go
    09-03-2014 07:00 AM
  11. jojopadz's Avatar
    This is mine. Any thoughts??
    09-03-2014 07:13 AM
  12. belodion's Avatar
    ^^^What's your screen-on time?
    09-03-2014 07:49 AM
  13. LeoRex's Avatar
    That percentage is really just a mapped value. Your phone's power management system monitors the voltage of the battery and reports that value back to the operating system. Internally, it then refers to a table that maps the voltage to a number value, which is then displayed. It isn't that your phone's charge is somehow miraculously staying at 100% for a long time, its just that the voltage reported is above the 100% threshold.... and it remains at 100% until the voltage hits the value mapped to 99%.
    Maybe it's a little bit of a psychological trick... battery obsessed people often get aggravated when their phones drop to 99% so quickly after charging full, so maybe they just played around with the mappings (which I suspect are somehow different when charging and discharging by the way) so that it 'hold's at 100% for a bit before dropping at a more normal rate.
    Stwutter, SFG14 and belodion like this.
    09-03-2014 09:13 AM
  14. Stwutter's Avatar
    Thanks.
    Funnily enough, on my Blackberry Z30, it never actually showed the percentages 99 & 98 on the home screen - only if you went into the battery monitor itself. So 100 would last for ages, and then... 97. Maybe BB like the psychological side of things too
    09-03-2014 09:37 AM
  15. jojopadz's Avatar
    Around 4 hours sry didnt take a screenshot. :P
    09-03-2014 09:54 AM
  16. LeoRex's Avatar
    Thanks.
    Well, I'm sure they fuss with these things to placate users. There is probably some statistician/engineer/psychologist somewhere in each of these OEMs whose job is to sit there and figure out the best way to map that percentage chart in order to give the impression of the longest battery life possible.
    LauraWA likes this.
    09-03-2014 10:01 AM
  17. Stwutter's Avatar
    Yeah. Quite possibly. A shame BlackBerry couldn't give a similar amount of time to employ a decent marketing manager...
    09-03-2014 10:08 AM
  18. king_alvarez's Avatar
    My battery is not good , i get like 4 sot daily .. Used to get 5 on my nexus5
    09-03-2014 10:10 AM
  19. jojopadz's Avatar
    So I was wondering how long the battery would last. I test it by charging to 100% waited a few minutes then started using it heavily. Until i get 1% down or 2. Then i went to setting and looked the battery etimatimed time. So it did shock me bacause it said 3~4 hours. And this was browsing trough internet. But yeah i dont know im not really scared this battery would fail on me because the idle is amazing. I skyped for 7 hours on speakers with closed cover and the battery went from 50% to 20%!
    09-03-2014 10:25 AM
  20. belodion's Avatar
    I'm outdoors in the sun now and am trying to see your screenshot stats, which I've forgotten, with two pairs of reading glasses on. If I'm reading them right, and I think I am, I'd say Brilliant battery performance.
    09-03-2014 12:11 PM
  21. Joltcola1234's Avatar
    This seems like normal behavior for my G3. The standby time is ridiculous on this phone, I take it off charge in the morning at about 6:00am and most days by 12:00pm it's still at 100% (with very little use). My battery drains steadily once below 100% and in use, but even then I like the battery on the G3. I've had plenty of days in the first month or so where I've gone 48 hours without charging.
    09-03-2014 11:22 PM
  22. durandetto's Avatar
    The g2 was the exact same way. 100% lasts a long time especially at idle.
    Sent from my LGLS990 using Tapatalk
    09-04-2014 12:34 AM
  23. AndroidHabit's Avatar
    What he said, try leaving you phone charging over night and when you take it off in the morning watch how long it stays at 100% the higher the voltage the battery has the longer it will last. Just charging it to full and removing it will not charge it completely and it will lose charge faster than if you left it over night.
    Stwutter likes this.
    09-04-2014 01:09 AM
  24. Stwutter's Avatar
    Yeah, that seems spot on. I took the phone off charge at work yesterday right when it buzzed to tell me it was 100%. It started losing battery steadily with normal use. This morning, having been charged overnight, it took nearly an hour of use to drop to 99%.
    As I've alluded to above, it's all good, but I'm not sure why 100% can't just mean 100%. Effectively, if you take the phone off charge as soon as it hits 100%, you're missing out on a few percentage points of battery.
    09-04-2014 02:02 AM
  25. Punyawee Werasopon's Avatar
    for me too... 100% will last for several hours after disconnected from the charger. but 30% to empty will reduce much quicker.
    by the way, after I changeto ART runtime and disable the Fast dormancy function. The battery life is much better lasting. I can finish my day at 30% for general use..
    waiting for android L. I hope G3 will be the perfect phone at that day
    09-04-2014 03:59 AM
28 12
  1. Samsung S4 Battery drains when on charger
    By Delia Brennan in forum Samsung Galaxy S4
    Last Post: 09-03-2014, 09:45 AM
  2. Sudden battery drain: Razr Maxx
    Last Post: 09-03-2014, 12:45 AM
  3. Replies: 1
    Last Post: 09-02-2014, 11:19 PM
  4. Replies: 0
    Last Post: 09-02-2014, 10:49 PM
  5. Battery friendly Music App
    By TomW093 in forum Android Apps
    Last Post: 09-02-2014, 10:11 PM
