Changing Fonts on LG G3
Erick Sims
4
So I'm trying to figure out how I would go about changing the system font on my LG G3. I am wanting to use a font from an installed font pack I obtained from the Google play store. Can anyone help me out? 🙏
I tried and failed. You can only download fonts from lg smartworld app... Other fonts from google play didnt work for me.
Not sure if you're willing to root or not but if you are there is a "root only" app called ifont that'll give you a ton of fonts you can apply.
Google "Smartworld apk" and then download it from there.
Mav :cool:
P.S. I like how you can use "Google" as a verb. :)
Sent from the future on my Sprint LG G3.
Got smartworld pre installed on mine in UK. The fonts aren't the best. But that's my opinion. I used Helvetica on my HTC one m7 but as stated you seem to have to root to change font on g3. Bummer really
Odgreen
