anker lg g3 battery
I don't quite get what you're asking?
Why buy a non-stock battery if it's the same size & price, as you say? Just get a real one?
And no NFC??? The only time a battery effects NFC is if you buy one of the massive 9000mah ones that require an alternative fat back cover (which is where the NFC chip is stored on the normal cover).
well i meant same capacity, coz a stock battery cost a lot, so this one could a nice back up.
regarding nfc, i didn't know the nfc chip was on cover because nfc chip for samsung are inside the battery
Fair enough. Personally, I'd buy an original, but if it's cheaper and just a back up, go for it if the reviews are ok.
I just checked and it looks like the Anker battery is currently on sale at $12.99 at Amazon. Love Anker batteries I am going to get one!
I just got a genuine LG replacement battery a month ago £40 UK. Still never used it as my battery life is amazing.
Anker has a good reputation for aftermarket batteries. And most of the "original" batteries for sale from 3rd party Amazon sellers and on eBay are fakes.
I've been using 2 Anker batteries and while they are much better than some of the cheap ones you find online, they are still not as good as the stock one. I have run the Anker batteries down several times to ensure a full capacity/charge and still don't get the same life of the stock, granted its not a huge difference, but I notice it.
I have looked to buy another stock battery and have yet to find one to order, even LG's site doesn't list these. Has anyone found REAL LG G3 batteries(not the fakes that look damn close)
snacks1233
