LG G3 - 2 Problems... Well Actually 3
With my LG G3, one of the first things that I have noticed is that if you have the dialpad on the screen while you are in a call it will occasionally allow your cheek to start pressing buttons, including end. I can switch the dialpad off thankfully, but I have to instead of it just detecting that my big head is next to it and prevent any buttons from being pressed. No question there i guess since I don't see any way to fix this besides LG fixing it themselves....
Second problem is with the Visual Voicemail. Last night it did it's notification that I couldn't sync my voicemails, which it could actually, but it decided to keep trying intensely for 3 hours while I was sleeping and drained my battery down from a full charge to 40%. That's when I was thankful for their charger because I could charge it in about an hour. Visual Voicemail has always had the tendency to bug me if it has 1 second where it can't sync the voicemail, which itself is very annoying. However, I have never had the problem of it draining my battery like this. Any solutions to their handy but terrible voicemail app?
The second problem leads me to the third problem with the phone. It doesn't let you keep your phone on the charger. I keep my phone on vibrate nearly all of the time and if I leave my phone on the charger it will keep vibrating and wake me up to force me to unplug it. If I could have just left it plugged in last night, I wouldn't have had the huge problem with it being drained over night. I have searched and searched for a way to turn this off, but I have not found one. Any new development on that?
Sorry about the rant. This is a great phone. I love it, but LG needs to fix these simple issues.
